Challenger 27 #1 Posted April 14, 2013 Just bought a Wheel Horse that needs SERIOUS cleaning of all EXTERIOR surfaces. I can tell the paint is in excellent shape, its just covered with years of crud! PROBABLY NOT CLEANED IN 10 YEARS. I DON'T want to damage the paint with a too aggressive cleaning product. What would you suggest? I need a strong, yet gentle on the paint, cleaning product. Your suggestions please. Thanks. Share this post Link to post Share on other sites
jay in nc 210 #2 Posted April 14, 2013 i'd mix 10 parts water to 2 parts kerosene & add some dawn dish soap & go to it with a soft brush. Jay Share this post Link to post Share on other sites
Shuboxlover 482 #3 Posted April 14, 2013 Simple Green!!!!! WORKS GREAT!!!!!!! Share this post Link to post Share on other sites
JC 1965 1,534 #4 Posted April 14, 2013 I also use Simple Green it is very gentle and cuts grease and oil. Share this post Link to post Share on other sites
Challenger 27 #5 Posted April 14, 2013 So Simple Green is SAFE on the tractor paint? Share this post Link to post Share on other sites
Shuboxlover 482 #6 Posted April 14, 2013 Simple green is safe on pretty much anything.....pet, kid, tractor etc. friendly 1 Share this post Link to post Share on other sites
Operator 7 #7 Posted April 15, 2013 My idea is to pull seat pan and console panels , load on trailer and go to local car wash, there use the presoak then do a good washing. It is what I do to mine every spring and they look like new after. Just my idea here. Share this post Link to post Share on other sites
VinsRJ 723 #8 Posted April 15, 2013 Simple Green.... is the way to go. Share this post Link to post Share on other sites
Kelly 1,033 #9 Posted April 15, 2013 I run them through the car wash to get the heavy crud off, then they are much easier to deal with at home. Share this post Link to post Share on other sites
Sparky-(Admin) 23,806 #10 Posted April 15, 2013 The local car washes here have big signs up that state you are not to be washing oil and grease off stuff (engines I suppose). Must have to do with environmental stuff and the fact that the oil and grease end up in the drains that go to who knows where . I think car washes are for cleaning the exterior of your car and not to de-grease anything. Mike............ Share this post Link to post Share on other sites
Docwheelhorse 2,792 #11 Posted April 15, 2013 I know it goes against what has been said here... but I have had some streaking/staining on tractors I have used simple green on the hood and fender pan.... just saying to be cautious. Simple Green is great stuff... just trying to save you a forehead slap----although maybe it was just my luck and perhaps being in the sun had something to do with it. Tony Share this post Link to post Share on other sites
Terry M-(Moderator) 2,266 #12 Posted April 15, 2013 The local car washes here have big signs up that state you are not to be washing oil and grease off stuff (engines I suppose). Must have to do with environmental stuff and the fact that the oil and grease end up in the drains that go to who knows where . I think car washes are for cleaning the exterior of your car and not to de-grease anything. Mike............ I know it goes against what has been said here... but I have had some streaking/staining on tractors I have used simple green on the hood and fender pan.... just saying to be cautious. Simple Green is great stuff... just trying to save you a forehead slap----although maybe it was just my luck and perhaps being in the sun had something to do with it. Tony The same goes for car washes near me. Big signs that say no greasey engine cleaning.(or something like that) There is a truck-wash near-by that lets you clean stuff like that. Just be careful And thanks for the simple green tip Docwheelhorse. Believe it or not, I was going to try that on my tractors whenever the snow goes away!! just maybe not the ones with nicer paint. Share this post Link to post Share on other sites
pacer 3,177 #13 Posted April 15, 2013 I wouldnt use any of the heavy duty cleaners - Simple Green, Purple Power, etc on nice paint unless greatly diluted, it can definitely cause streaking if used too strong, and its too late to do anything about it then. I use Purple undiluted to do my heavy cleaning and it will often take the paint OFF! Share this post Link to post Share on other sites
BOWTIE 226 #14 Posted April 15, 2013 I USE A PRESSURE WASHER WITH JUST WASHER FIRST. THEN KEROSENE THE GREASY AREAS WITH A PAINT BRUSH AND PRESSURE WAS IT AGAIN. NOW I USE DAWN SOAP IN A BUCKET OF HOT WATER. I ALWAYS TO THE HOOD AND FENDER LAST AND DON'T LET IT LAY ON THE NICE FINISHES. THEN RUN A BUFFER OVER IT AND WAX. BOWTIE 1 Share this post Link to post Share on other sites
sorekiwi 761 #15 Posted April 15, 2013 Purple Power will remove paint or streak it. I'd stay away from it for what you want to do. I've had good luck with Simple Green but I dont leave it on too long. I spray it on full strength, work it around a bit with a brush and hose it off within about 15 minutes. Share this post Link to post Share on other sites
64s 83 #16 Posted April 15, 2013 I used a product from Dollar Tree a couple of years ago - I think it was called 'Awesome' cleaner. I put some in a spray bottle to clean the engine on a 856 and put the bottle on the hood when finished. When I picked up the bottle there was a perfect clean ring where the bottle was, so I poured a little on the hood and just let it run down. Not only did the paint look much newer than the surrounding oxidized paint, but 3-4 years later the area still looks better and it seems like it didn't harm the paint, only removed the oxidation. Sadly I never tried it on the whole tractor as I put it to work the minute it was running, but maybe I'll look for the stuff again and this time do the whole thing. Share this post Link to post Share on other sites
joeshorse 0 #17 Posted April 15, 2013 Purple Power has alkali in it which etches your paint........try something genltler like dish washing soap. Share this post Link to post Share on other sites
DoctorHfuhruhurr 137 #18 Posted April 15, 2013 no pics? Share this post Link to post Share on other sites
varosd 1,185 #19 Posted April 15, 2013 The local car washes here have big signs up that state you are not to be washing oil and grease off stuff (engines I suppose). Must have to do with environmental stuff and the fact that the oil and grease end up in the drains that go to who knows where . I think car washes are for cleaning the exterior of your car and not to de-grease anything. Mike............ I agree with Mike, I just got off the local trout stream and catch/released 3 nice Brown trout. Please keep our streams and waterways clean! Trout Unlimited! 1 Share this post Link to post Share on other sites
JimD 3,347 #20 Posted April 15, 2013 Dawn dish washing liquid is an excellent grease cutting soap that shouldn't harm your paint. Many machine shops use it to clean their parts before shipment. Share this post Link to post Share on other sites
hm12460 53 #21 Posted April 18, 2013 Another vote for Dawn dish soap. Share this post Link to post Share on other sites
smoreau 658 #22 Posted April 18, 2013 (edited) Depending on the tractor I use purple power, simple green, dawn, and car wash soap. The workers that are not so nice and have oil leaks get the strong stuff as looks are not important as keeping it clean and well maintained. As for the nice, but non restored tractors, Dawn is best. And last are the nice restored tractors. well I find that you just don't let them get that dirty and they are always well taken care of, so only car wash soap is needed and a soft cloth and shammy dry is all that is needed. So it depends on the tractor and its condition. if its a nice tractor, then use genital cleaners, but if its a worker and doesn't look all that great with lots of leaks, Harsher cleaners are needed. Edited April 18, 2013 by smoreau Share this post Link to post Share on other sites
Hodge71 690 #23 Posted April 18, 2013 So it depends on the tractor and its condition. if its a nice tractor, then use genital cleaners, but if its a worker and doesn't look all that great with lots of leaks, Harsher cleaners are needed. Use genital cleaners?!!! ...holy moly...not cleaning my tractor with anything i use on genitals.... cmon...that was funny.... 1 Share this post Link to post Share on other sites
smoreau 658 #24 Posted April 18, 2013 ok that one slipped buy!! funny know but you know what I meant 1 Share this post Link to post Share on other sites
sorekiwi 761 #25 Posted April 18, 2013 Definately not using Purple Power anywhere near my genitals, I've seen what it does to the skin on my hands! 1 Share this post Link to post Share on other sites
