TomB 2 #1 Posted April 12, 2013 I have inherited wheelhorse (1960s) K161S that needs a vacuum fuel pump. Anyone know where I can get one? Share this post Link to post Share on other sites
squonk 45,565 #2 Posted April 12, 2013 Is the pump missing or does it need repairing? Share this post Link to post Share on other sites
TomB 2 #3 Posted April 12, 2013 I have the pump it just needs repair. Did not know it could be repaired ??????????? Share this post Link to post Share on other sites
WH nut 553 #4 Posted April 12, 2013 You can put a mechanical one on, the cam lobe is there. Share this post Link to post Share on other sites
TomB 2 #5 Posted April 12, 2013 The cam didn't look like it was centered so we weren't sure we could use a mechanical. Which one do you recommend? Share this post Link to post Share on other sites
WH nut 553 #6 Posted April 12, 2013 The cam didn't look like it was centered so we weren't sure we could use a mechanical. Which one do you recommend? The last time I replace one I grabbed any mechanical pump Share this post Link to post Share on other sites
rmaynard 16,880 #7 Posted April 12, 2013 The pump arm on a K161 mechanical pump is offset to be able to hit the cam. Your vacuum pump can be rebuilt. If it is just the diaphragm, contact member buckrancher for a new one. Share this post Link to post Share on other sites
WH nut 553 #8 Posted April 12, 2013 The pump arm on a K161 mechanical pump is offset to be able to hit the cam. Your vacuum pump can be rebuilt. If it is just the diaphragm, contact member buckrancher for a new one. The pump arm on a K161 mechanical pump is offset to be able to hit the cam. Your vacuum pump can be rebuilt. If it is just the diaphragm, contact member buckrancher for a new one. Thanks, good to know. I must have gotten lucky and grabbed the right one. Share this post Link to post Share on other sites
