wh17 1 #1 Posted April 11, 2013 My friend has a tractor he bought the guy claimed it was a 14 but the engine shield say k301 I was wondering if there was a way to know for sure with out taking the head off and it's on a cub cadet so i can't see what it says on the block thanks Share this post Link to post Share on other sites
Sparky-(Admin) 24,524 #2 Posted April 11, 2013 I think you'll have to take the head off and measure bore and stroke. They both have 9 head bolts and the tin can be swapped so there will be no clues there that you can trust. Mike........... Share this post Link to post Share on other sites
Don1977 605 #3 Posted April 11, 2013 301 standard bore is 3 3/8" and the 321 standard bore is 3 1/2" the stroke is the same 3 1/4". Share this post Link to post Share on other sites
Wheel-N-It 2,978 #4 Posted April 11, 2013 The 301 I am working on now has K301 raised on the engine block above the pto side of the crank Share this post Link to post Share on other sites
SCOOBY 312-h 14 #5 Posted April 11, 2013 some 301's have that mark some dont,,,,,,you definatly want to measure the bore and the stroke. i just bought a 301 from a guy for my cub and it doesnt have any marks on it that say 301 except the flywheel shroud. and if you have k301 on the flywheel shroud it should be a 12 horse kohler, if im not wrong the 14 horse shroud will not fit the 12 horse engine. Share this post Link to post Share on other sites
oldredrider 2,553 #6 Posted April 11, 2013 Some 10hp series Kohlers have the K301 casting number on the block. That does not make it a 12hp. Just means the block has enough "meat" to be bored to 12hp bore. Share this post Link to post Share on other sites
WH854 45 #7 Posted April 11, 2013 Some 10hp series Kohlers have the K301 casting number on the block. That does not make it a 12hp. Just means the block has enough "meat" to be bored to 12hp bore. Ditto I have a 10 HP with K301 on the PTO side Chas Share this post Link to post Share on other sites
Don1977 605 #8 Posted April 11, 2013 I have a K-301 13 fin block that has E16 cast into it. Share this post Link to post Share on other sites
Wheel-N-It 2,978 #9 Posted April 12, 2013 Some 10hp series Kohlers have the K301 casting number on the block. That does not make it a 12hp. Just means the block has enough "meat" to be bored to 12hp bore. Ditto I have a 10 HP with K301 on the PTO side Chas Thanks much guys! I learned somethng new today Share this post Link to post Share on other sites
