rprevost 0 #1 Posted April 10, 2013 I just had the solenoid replaced on my 518H. When it came back from the shop, I tried to mow with it; however, when I engaged the PTO, the engine would shut down, very like it would do if you happened to fall of the mower while mowing. I looked at the switch and when I engage the PTO and manually press down the levers on the switch, the mower will continue to run. I am trying to figure out what is going on. Could something have been switched at the solenoid replacement such that the safety switch on the PTO is backward? Any help will be appreciated. Rob Prevost Monroe, NC Share this post Link to post Share on other sites
stevebo-(Moderator) 8,495 #2 Posted April 10, 2013 You may have faulty seat safety switch. Check that out first. 1 Share this post Link to post Share on other sites
dbartlett1958 99 #3 Posted April 11, 2013 I think Steve is right on this one. I had a similar experience on my 416 when mowing. What happened was when I turned, I would lean a bit in the seat and the switch would trip and cause the tractor to stumble, or actually cut out. I thought carb at first, but turned out to be the seat switch. Share this post Link to post Share on other sites
WH nut 553 #4 Posted April 11, 2013 I just had the solenoid replaced on my 518H. When it came back from the shop, I tried to mow with it; however, when I engaged the PTO, the engine would shut down, very like it would do if you happened to fall of the mower while mowing. I looked at the switch and when I engage the PTO and manually press down the levers on the switch, the mower will continue to run. I am trying to figure out what is going on. Could something have been switched at the solenoid replacement such that the safety switch on the PTO is backward? Any help will be appreciated. Rob Prevost Monroe, NC Make sure the PTO lever fully engages the PTO switch, I have seen some levers slide back and forth and miss the switch Share this post Link to post Share on other sites
Wh416H 24 #5 Posted April 11, 2013 I had the same problem last week it was a bad connection on the seat switch Share this post Link to post Share on other sites
rmaynard 16,204 #6 Posted April 11, 2013 (edited) Here's the wiring diagram for the 518-H. This may help you in your search for the offending gremlin. The PTO switch appears to have two leads coming off of it. One orange and one brown. Looks to me like the orange wire is disconnected at one end or the other. Edited April 11, 2013 by rmaynard Share this post Link to post Share on other sites
rprevost 0 #7 Posted April 11, 2013 Thanks for all the help. I am going to check the seat switch this weekend and will let y'all know what happened. RP Share this post Link to post Share on other sites
rprevost 0 #8 Posted April 14, 2013 I started to look at my tractor this weekend. Given the responses to this post, I thought that I would replace the seat switch first. Then I realized that, as a new owner of a Wheelhorse, I don't know where to get parts. I can get an original part replacement from Toro or a vendor on Ebay. Here is my question: is this a common part that I could get down at Lowes' or any mower repair store, or does it need to be an original part from Toro/Wheel Horse? Rob Prevost Share this post Link to post Share on other sites
WH nut 553 #9 Posted April 14, 2013 Here's the wiring diagram for the 518-H. This may help you in your search for the offending gremlin. 518-H Run.png The PTO switch appears to have two leads coming off of it. One orange and one brown. Looks to me like the orange wire is disconnected at one end or the other. Most Diagrams show the circuit in the rest position but looking at this one it looks like with the PTO engaged which sends the jusice through the seat switch disengaged it goes around it Share this post Link to post Share on other sites
WH nut 553 #10 Posted April 14, 2013 I started to look at my tractor this weekend. Given the responses to this post, I thought that I would replace the seat switch first. Then I realized that, as a new owner of a Wheelhorse, I don't know where to get parts. I can get an original part replacement from Toro or a vendor on Ebay. Here is my question: is this a common part that I could get down at Lowes' or any mower repair store, or does it need to be an original part from Toro/Wheel Horse? Rob Prevost Quick test, jumper Brown to orange at the seat switch and see if it still acts up. Or better yet, jump the 2 wires at the seat switch. It should run whether the PTO is engaged or not Share this post Link to post Share on other sites
ron.cieri.313 0 #11 Posted April 29, 2013 Question...I just re-installed my mower deck onto my C-100 after renovating (clean, new bearings in the spindle, new blades, etc.)...my tractor runs strong but I've never engaged the PTO with the mower deck on since buying the maching in Jan. and have been refurbishing...the seat switch is disconnected...the wires have been cut and capped. I have the same problem as listed in the post...I figured i just hadn't let her warm up enough and the power transfer was causing her to shutdown...but I can turn the the belt by hand pretty easily...can the mower deck run with seat safety switch not connected to the pto switch?...guess I'll go back and study the darn wiring diagram again...but any help is appreciated...thanks, ron. Share this post Link to post Share on other sites
WH nut 553 #12 Posted April 29, 2013 Question...I just re-installed my mower deck onto my C-100 after renovating (clean, new bearings in the spindle, new blades, etc.)...my tractor runs strong but I've never engaged the PTO with the mower deck on since buying the maching in Jan. and have been refurbishing...the seat switch is disconnected...the wires have been cut and capped. I have the same problem as listed in the post...I figured i just hadn't let her warm up enough and the power transfer was causing her to shutdown...but I can turn the the belt by hand pretty easily...can the mower deck run with seat safety switch not connected to the pto switch?...guess I'll go back and study the darn wiring diagram again...but any help is appreciated...thanks, ron. Twist the 2 wires together at the seat switch and that will bypass the switch Share this post Link to post Share on other sites
