WH nut 553 #1 Posted April 9, 2013 Have to be quick on the kill switch. 2 Share this post Link to post Share on other sites
AMC RULES 37,235 #2 Posted April 9, 2013 Yeah...that could leave a mark. Share this post Link to post Share on other sites
Jake Kuhn 1,581 #3 Posted April 9, 2013 I've done that on my black 401 a couple of times catching on a tree root I think. It can be scary! I took pictures once but I think I deleted them, it was higher than yours was in the front. Jake Share this post Link to post Share on other sites
JUSS10 250 #4 Posted April 9, 2013 I've had that issue with my 854. I actually made a front "mast" that hangs off the tractor to keep weight out front. i would hang 50lbs about 12" in front of the front axle. I know that doesn't help with roots per say, but it does keep the front end down when plowing and makes it less susceptible to pull up. I did that with my 1054 once, had it way up high, that was pretty scary! Justin 1 Share this post Link to post Share on other sites
doc724 925 #5 Posted April 9, 2013 I had a few of those over time. Sold my plow with my 314. Kids all grew up and moved on. No need for a big garden anymore. I kinda miss it at this time of year. Share this post Link to post Share on other sites
SCOOBY 312-h 14 #7 Posted April 9, 2013 i can honestly say i have never plowed like that but that would make me nervous a little. the only time i tiped a tractor up like that is when i was doin wheelies. did you have to dig it out or could you back out of it? Share this post Link to post Share on other sites
leeave96 490 #8 Posted April 9, 2013 Could have been worse - you could have hit a power or gas line... 2 Share this post Link to post Share on other sites
6wheeler 670 #9 Posted April 9, 2013 Nice...... You get used to that after awhile . I use front end weights too. By the way, The front end of a 520 will do the same thing. Even with front weights. As mine would tell you Share this post Link to post Share on other sites
groundhog47 347 #10 Posted April 9, 2013 Happened to me once on a bigger unit, when turned around and saw had mili seconds to hit clutch or Ida been an ER number, so glad you caught before it got rared up too much.Powerful little booger, isn't he!! Share this post Link to post Share on other sites
JUSS10 250 #11 Posted April 9, 2013 Could have been worse - you could have hit a power or gas line... I actually hit a gas line last year with my homemade subsoiler... lucked out as it was a plastic line that was run to the barn. Kinked it but it worked itself out in a day or two. But yeah, be aware of what beneath the ground before you drop a plow! Share this post Link to post Share on other sites
WH nut 553 #12 Posted April 9, 2013 I've done that on my black 401 a couple of times catching on a tree root I think. It can be scary! I took pictures once but I think I deleted them, it was higher than yours was in the front. Jake It was standing on end, this is after i got off it and got the cell phone out to take a picture. It had settled by then i can honestly say i have never plowed like that but that would make me nervous a little. the only time i tiped a tractor up like that is when i was doin wheelies. did you have to dig it out or could you back out of it? Just backed it out after changing britches Share this post Link to post Share on other sites
can whlvr 994 #13 Posted April 9, 2013 you got lucky,i was dragging a large rock one time and it caught a root,flipped the tractor on top of me faster than a blink of an eye,got stabbed by the implement lifting arm,and the tires were flailing on me,it wasnt pretty Share this post Link to post Share on other sites
WH nut 553 #14 Posted April 9, 2013 you got lucky,i was dragging a large rock one time and it caught a root,flipped the tractor on top of me faster than a blink of an eye,got stabbed by the implement lifting arm,and the tires were flailing on me,it wasnt pretty This wasnt the first time she bucked, had my hand on the kill switch. Much better to kill it then try to reach the clutch and throw my weight further back Share this post Link to post Share on other sites
