MaineDad
Motor Housing Gasket Tourque
MaineDad
Guys,
The Sundstrand tranny is working well but leaking from the motor housing. I bought a new gasket and installed it but it is still leaking. How much torque using a torque wrench do you recommend I use?
Thanks,
Micah
Buzz
Don't know from experience but here's a torque chart to use as a guideline. good luck. I'm following your repairs closely because I just bought my first automatic and when I start working on it I'll be reviewing what you did.
http://www.morbark.com/Service/belttorque.pdf
MaineDad
Thanks Buzz...
I torqued mine down to 60 lbs and your chart recommends much more. I'll try later.
Good luck with your tractor. I have her running fine now but it leaks like a you know what B)
