MaineDad 87 #1 Posted August 9, 2008 Guys, The Sundstrand tranny is working well but leaking from the motor housing. I bought a new gasket and installed it but it is still leaking. How much torque using a torque wrench do you recommend I use? Thanks, Micah Share this post Link to post Share on other sites
Buzz 502 #2 Posted August 10, 2008 Don't know from experience but here's a torque chart to use as a guideline. good luck. I'm following your repairs closely because I just bought my first automatic and when I start working on it I'll be reviewing what you did. http://www.morbark.com/Service/belttorque.pdf Share this post Link to post Share on other sites
MaineDad 87 #3 Posted August 11, 2008 Thanks Buzz... I torqued mine down to 60 lbs and your chart recommends much more. I'll try later. Good luck with your tractor. I have her running fine now but it leaks like a you know what B) Share this post Link to post Share on other sites
