Wheel-N-It 2,976 #1 Posted April 7, 2013 Well the M10 Jay and I installed in the 310-8 roller I bought from him was a dud, so yesterday I began getting rid of the 10hp Magnum and replacing it with a K-301 12hp I had sitting around the shop taking up valuable space. So why didn't I put that engine in to start with you might ask??? Good question. The reason was the little 310 was already set up for a Magnum engine, and I did not want to go through all wiring changes to convert it over to a K engine if I did not need to. Basically it was a plug and go installation. Besides I got the Magnum engine as a freebie, and I wanted to see how good or not good (in this case) it ran. The Magnum 10 ran, but smoked badly, had alot of blowby, and not much compression. I had run the K engine in a Wheel Horse I bought last year, and it seemed to run reasonably well. The Wheel Horse was a short frame, and was too small for me physically to use and be comfortable. So anyway, my Son-In-Law wants to do some tilling at his (and my daughter's) house, he got a Wheel Horse for Christmas (from me), and I thought "Why not fix the 310 up for tilling?". So here's the project. If all goes well, it will be a tilling tractor. I can keep the tiller on it year round, and install the really cool attach-matic weight bar that Jay-In-NC made for me to help hold the front end down. Its a shame to let that nice weight bar just set on the work bench in my shop when it could be mounted on a Wheel Horse. Back to the wiring, I aborted all the Magnum wiring (safety switches and all), and will be rewiring all new for the K-engine, ignition switch and all. Here are some pics for you to enjoy if you are still awake after reading all this. Share this post Link to post Share on other sites
jay in nc 210 #2 Posted April 7, 2013 cool, i wonder why it took so long to put that k into that frame after we figured out the mag motor was junk. oh by the way to all members i have the 1067 auto that this engine came on! now repowered with a N.O.S. hh120 tecumpseh. so what we basicly we just traided rolling chassies. good luck with the dedicated tiller tractor van. Jay 1 Share this post Link to post Share on other sites
leeave96 490 #3 Posted April 7, 2013 Van - looking good, much easier engine swap than my YELLER tractor I'm working right now - LOL Share this post Link to post Share on other sites
Wheel-N-It 2,976 #4 Posted April 7, 2013 (edited) Jay it took so long because I wanted to wait till Spring was here for good! Me no likey cold weather! Me rather sit next to wood stove than work on cold Wheel Horses. Hey, I need a starter for that K-301. I might be asking you if you have one you will sell me. It looks like the one off the M10 will not fit on the K301. Any ideas or do I need new reading glasses??? I used the one off the K301 on the K341 in the 416-8. Bill, I know bout your Yeller Tracter engine swap. I am keeping up with that thread on OnlyCubCadets! Once the new engine is running and the tractor moves under its own power I will be giving it one more good pressure wash. I took the roller to the local car wash this morning before bolting the K engine on. It will need another good scrubbing before bolting all the fender pan and seat and whatever stuff back on, and installing the tiller and front weight bar. Hopefully I can do a little more tomorrow. Edited April 7, 2013 by Wheel-N-It Share this post Link to post Share on other sites
can whlvr 994 #5 Posted April 7, 2013 the magnums definatly use a different way to attach the starter than the k,s you have to watch the 1/4 inch bolts that hold the magnums on,they can strip or break Share this post Link to post Share on other sites
Wheel-N-It 2,976 #6 Posted April 8, 2013 Small update. I had a couple of hours to work on the rewiring this afternoon. I knstalled a new ignition keyswitch, and made a new wiring harness for the +side of the coil, the "B" terminal of the regulator, the starter relay, power supply from the starter relay tap point to the ignition switch, and a new wire over to the line side of the headlight switch. I incorporated the old voltmeter wiring in with the new. The headlight wiring will go in after the hood is put back on. Now I need a fuse for the new fuse holder, a battery, and a starter. Here are today's pics. Share this post Link to post Share on other sites
Wheel-N-It 2,976 #7 Posted April 18, 2013 I bought a really good lightly used kohler starter this past weekend that I found on CL. Yesterday got a new battery from Advance Auto. Put all that in when I got home from work yesterday, hit the key switch and..................... nothing. No big deal though, the starter relay is bad. So I jumped across the terminals and the K-301 fired right up and purred like a big ole' fat kitten. I have a spare relay, and hopefully it works. If not then I can pick up something at NAPA. Anyway, I'm getting closer to having this thing together and working. My Son-N-Law told me he will replace the seals in the tiller. That takes a little work off me. BTW, the K engine is a 1977 vintage according to the numbers. Share this post Link to post Share on other sites
Wheel-N-It 2,976 #8 Posted April 29, 2013 Well this hasn't taken too terribly long to do. Mechanically the tractor is now finished. I will get some pics after the weather clears up so you al can see it in the Sunshine. The new (1977 K301) runs great! I am very happy with how it sounds and performs. Here is what I did to make the conversion; 1: Remove the M10 that was running but just plain worn out and re: place it with a 1977 K301aqs 2; Install new ignition switch and starter relay 3: Remove all the old wiring and replace with new automotive grade stranded wire, including a new fuse holder for the main ignition/starting circuit 4: Remove the PTO assembly from the M10 and install it on the K301 (the wheel horse I pulled the K motor from was missing the PTO assembly. 5: Install a new shifter boot (Thanks Jay) 6: Install newer front tires and wheels from a 312-8 (these tires actually hold air and the bearings are good) 7: Soak the drive belt idler pully overnight in LE 15/40 (nice and quiet now) 8: Clean the carb reallyreally good and install a new air filter 9: Replace the starter with an almost brand new Kohler starter I bought on CL (reason for this is I used the K301 starter on another K engine on a different Wheel Horse) 10: Installed new anti-rattle trim on the hood where it mates to the dash tower 11: Greased and lubed everything on the chassis, and greased the roller bearings on the PTO bell 12: Used all new bolts where necessary 13: New battery and good used battery tray It runs and drives great! The engine starts easy, hot or cold. I am really happy with how it turned out. Next phase for this Wheel Horse is to install the rear axle bracket, lift cable, and rock shaft to mount the tiller. Hopefully I will be able to post some pics next weekend as its going to rain here through Wednesday. Share this post Link to post Share on other sites
leeave96 490 #9 Posted April 30, 2013 Van - you are making great progress! You strike me on getting these tractors going as 3rd gear high range, where I am 1st gear low range... 1 Share this post Link to post Share on other sites
