Herbiegrizz 1 #1 Posted April 4, 2013 My friend just bought what we think is an rj35 Its belts on the right side,,I have a rj58 and the rear end is totally different.Did the rj 35 have brakes and does it have a reverse..We know it has wrong engine on it Share this post Link to post Share on other sites
CasualObserver 3,414 #2 Posted April 4, 2013 I can't believe no one's piped up yet.... yes, Rj-35s have reverse, and the brake kit was an option. do a search from the main page, there are lots of topics about it. Share this post Link to post Share on other sites
Herbiegrizz 1 #3 Posted April 4, 2013 Thanks He was trying to find out what he has ,Thanks again Share this post Link to post Share on other sites
Jake Kuhn 1,598 #4 Posted April 4, 2013 Any pictures of the tractor? Share this post Link to post Share on other sites
Herbiegrizz 1 #5 Posted April 4, 2013 Ill have to take some when I see him Share this post Link to post Share on other sites
VinsRJ 723 #6 Posted April 5, 2013 Reverse is engaged when the speed selector is pulled toward the rider fully... at which point a bronze friction disc on the engine pulley will engage a groove on the veri-drive, thus reverse rotating the belt system. As stated above the brake kit was an option and not all RJ35s had them, the kit consisted of a foot lever, hood stand cable mount, a cable and sheath, gear case cover mount and a band brake. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #7 Posted April 5, 2013 and.... once you use the reverse one time you will not do it again!! Metal on metal is not a sound I like to hear... Share this post Link to post Share on other sites
Jake Kuhn 1,598 #8 Posted April 5, 2013 and.... once you use the reverse one time you will not do it again!! Metal on metal is not a sound I like to hear... There's nothing wrong with that sound! I use mine quite a bit LOL Share this post Link to post Share on other sites
jeremi3210 743 #9 Posted April 5, 2013 How long does the reverse disk last? Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #10 Posted April 5, 2013 All depends how much you use it.. lol Mine will last forever and Jake needs to replace his every year.... 1 Share this post Link to post Share on other sites
jeremi3210 743 #11 Posted April 5, 2013 Kinda what i figured. I dont use mine them things are little and easy to push around. Share this post Link to post Share on other sites
VinsRJ 723 #12 Posted April 5, 2013 I don't even install the reverse disc... no chance to hear that sound and no chance to wear it away... additionally without it installed it gives you a little more range to reach and stay in nutral. Share this post Link to post Share on other sites
russtiron 41 #13 Posted April 5, 2013 Is there a source for the cable? Mine is missing is it the same as a impliment lift cable? Thanks Chuck Share this post Link to post Share on other sites
