kaiser 100 #1 Posted April 3, 2013 i couldn't find a manual for my exact year and model in the downloads section, is this one close enough (for everything except the engine of course) ? if not, which one is the closest? thanks, pete- Share this post Link to post Share on other sites
Don1977 605 #2 Posted April 3, 2013 That should be the same as the 1983 1642. Share this post Link to post Share on other sites
kaiser 100 #3 Posted April 3, 2013 thanks don, thats what i figured, just wanted someone to confirm it. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,757 #4 Posted April 4, 2013 Toro lists your tractor as using a model 5086 8-speed transmission with 4-pinion differential and 1" axles. Have a feeling that should be a model 103916 8-speed transmission with 8-pinion differential and 1-1/8" axles. Which is correct? Garry Share this post Link to post Share on other sites
kaiser 100 #5 Posted April 4, 2013 actually the previous owner installed the 8 pinion diff with 1 1/8 axels from a c series. stock it had the 4 pinion, 1" axels. thanks for giving me the model# to my new trans though. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,757 #6 Posted April 6, 2013 actually the previous owner installed the 8 pinion diff with 1 1/8 axels from a c series. stock it had the 4 pinion, 1" axels. thanks for giving me the model# to my new trans though. Don't count on that being the transmission model number. The 103916 was used mainly in 1978-79. This is the service bulletin that made me think the 5086 was not correct but maybe they used the alternate bearings in it also. http://www.wheelhorseforum.com/files/file/1841-wh61-90-369-inner-axle-bearing-1984-gt-series-c-series1pdf/ Garry Share this post Link to post Share on other sites
