mattd860 162 #1 Posted April 2, 2013 The left side needle bearing right behind the axle seal is noisy on my 753. It is possible to replace it without taking apart the transmission? I would like to do it when I replace the axle seals. Share this post Link to post Share on other sites
stevasaurus 23,355 #3 Posted April 2, 2013 You lucked out though Matt. Being on the left side, you just have to split the trans and take that half of the case off...do not have to take any of the gears out. Bearing is Torrington # B-1616. Share this post Link to post Share on other sites
groundhog47 347 #4 Posted April 2, 2013 (edited) The left side needle bearing right behind the axle seal is noisy on my 753. It is possible to replace it without taking apart the transmission? I would like to do it when I replace the axle seals. Believe have some NOS bearings still, PM sent and will verify Wed when get back home, thanks. I was wrong they are 1" axle bearings. Edited April 2, 2013 by groundhog47 Share this post Link to post Share on other sites
stevasaurus 23,355 #5 Posted April 2, 2013 Gerry, he has 1" axles...it is a 5025 transmission. Share this post Link to post Share on other sites
groundhog47 347 #6 Posted April 3, 2013 (edited) Ok, I see now they are stamped b1616, so will PM matt... Gerry, he has 1" axles...it is a 5025 transmission. Edited April 3, 2013 by groundhog47 1 Share this post Link to post Share on other sites
