Countryboy94 0 #1 Posted April 2, 2013 Hey guys I'm new to this community I got a problem with my voltage regulator not sure if I got it hooked up backwards or not but once I disconnect a backup battery the tractor does after a minute or so if you guys got a voltage regulator wiring diagram for a 1967 wheel horse model 877 it'd be greatly appreatied Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,393 #2 Posted April 2, 2013 The operator manual has a diagram of the tractor wiring http://www.wheelhorseforum.com/files/file/1298-tractor-1967-877-om-ipl-wiring-877pdf/ This is a Kohler manual that has a section on the starter/generator Garry Share this post Link to post Share on other sites
Countryboy94 0 #3 Posted April 2, 2013 Would it have a difference if I upgraded the motor the voltage regulator should still be fine correct Share this post Link to post Share on other sites
