carlsbarn2
axle-hub distance
carlsbarn2
 On my 310-8 ,right side hub became loose on axle.I  How far should axle stick out of hub ? Left side is flush,
RCTruckDaddy
Flush
sorekiwi
What he said!  ^^^^^^^.
What you actually want is the setscrew to press directly on the middle of the woodruff key - this prevents it from rocking in its groove.  The axles are designed so that when the end of the axle is flush with the hub, the setscrew is in the correct location.
carlsbarn2
Thank you. I will loosen them both and move hub to end of shaft.
