Stigian 1,235 #1 Posted August 9, 2008 You all know "those" sort of jobs, yes thats it, the kind of job you put off for as long as poss for no real reason This job involved sorting the battery mounting out on my 312-8, as much to my shame the batt had been held in place with a block of wood, a bungie strap and some duct tape When i pulled apart the AYP i got from freecycle a long while back, i kept the under seat battery box just for this very job. With only a slight bit of trimming one side it fitted a treat Not wanting to drill any extra holes in the 'orses body work, i drilled out the rivets that hold the hood strap hook 's and put in some small bolts to hold everything in place The two lumps of wood were screwed together and screwed up through the bottom of the batt box to keep them where they are, and to keep the batt held firm The battery is from a Kawasaki Gpz305, and despite its small size the 312 never fails to start first turn of the key Share this post Link to post Share on other sites
Docwheelhorse 2,869 #2 Posted August 9, 2008 HI--looks like a neat enough job ---BUT--- how does that litlle itty bitty motorcycle battery have enough gumption to turn over the Kohler DO you run those all the time or did you "find" it and used it like we all do---ANY 12 volt battery that is charged will work for now (which turns into forever--or until the battery quits!!) TOny Share this post Link to post Share on other sites
Stigian 1,235 #3 Posted August 9, 2008 Hi Tony, i don't run bike batts all the time although maybe i should if they all work the same as this little one I bought that batt new 2 maybe 3 years ago for the kwacker 305 to get it running, and then broke the bike up 2-ish years later it was dragged out the cupboard, charged up and put in the 312 when i pinched the batt out of it for the Raider 10 Its a great little battery, i know the 312 will start first time every time and has done for the past 5-sh months :whistle: Share this post Link to post Share on other sites
BairleaFarm 344 #4 Posted August 10, 2008 If it works run it. Ive done worse B) Share this post Link to post Share on other sites
mcwh1950 2 #5 Posted August 10, 2008 a lot of the old mtd take the same battery Share this post Link to post Share on other sites
