4hokies 3 #1 Posted March 29, 2013 I've got a 520H with a 48" mower deck. One of the spindles has broken at the flange, so now I only have three mounting bolts instead of four. Has anyone tried to weld these? (I have the both pieces) Is the housing cast aluminum or cast iron? These are nearly $70 new, so I'm try to save some money. Share this post Link to post Share on other sites
Cable 180 #2 Posted March 29, 2013 Everyone that I have seen with missing bolt holes also had a bent shaft. You may want to remove the shaft and make sure it is straight. I lay mine on a joiner table a watch to see if it rolls one way or another. I now have a good deck with the same issue. The spindle housing plus shaft makes repair rather costly. I hope to find a junked deck to get needed parts. Share this post Link to post Share on other sites
4hokies 3 #3 Posted March 29, 2013 Thanks for the tip, I'll check the shaft. Regardless of the shaft, It still might be cheaper to weld the housing rather than replace it. Share this post Link to post Share on other sites
can whlvr 994 #4 Posted March 30, 2013 ive ran some with only 3 holes,it worked for years till i got a parts deck and replaced it Share this post Link to post Share on other sites
BOWTIE 226 #5 Posted March 30, 2013 THE HOUSING IS ALUMINUM. IF IT CAN BE WELD THAT WOULD BE GREAT. IF NOT ROTATE IT WITH THE LEFT OUTER, THERE WILL BE LESS LOAD ON THAT ONE. ARE THE 3 GOOD MOUNTING HOLES STILL GOOD AND SOLID? I HAVE RAN A 3 BOLT MOUNTING FOR QUITE A FEW YEARS WITH NO PROBLEM. BOWTIE IN OHIO Share this post Link to post Share on other sites
4hokies 3 #6 Posted March 30, 2013 Bowtie - Thanks for the info Share this post Link to post Share on other sites
Tankman 3,523 #7 Posted March 31, 2013 I have a couple of decks with spindle flanges eaten (corrosion) away, have been working fine for a few years. I was thinking of a flange w/ matching threaded bolt (mounting) pattern. Longer mounting bolts, clearance hole for the shaft assembly housing in the center. The flange would slide down over the spindle. Any thoughts? Further corrosion has stopped 'cause I clean and park the Horses indoors. My herd was all second hand, poor outdoor housing, bad condition. Took a lot of elbow grease and Horse liniment to get 'em up and out to pasture. Who would treat a thoroughbred Stallion so poorly? While discussing decks, any easy way to install the 48" SD deck spindle belt? Always gives me a pain in the you-know-what! Retired, additional pains I can live without. Guess I was cryin' before I was hurt. Put new belt on, ten minutes. Like duh! Share this post Link to post Share on other sites
Don1977 604 #8 Posted April 4, 2013 The grass deteriorating on the aluminum eats them away. I started painting mine last spring when I cleaned and repainted the under side of my deck. I just used Rust-oleum primer and paint that I had. Epoxy would be a lot better as I think it would last longer. I will get some epoxy before I do it again. Some of the paint was worn off the deck in spots last fall I will touch up before installing the deck. Share this post Link to post Share on other sites
Forest Road 594 #9 Posted April 4, 2013 I have some good used spindles available. PM me for info. Share this post Link to post Share on other sites
