coolhandblack 45 #26 Posted April 1, 2013 after looking at some others that you guys have made, as soon as the weather warms up I think I will do some modifying to mine. The rake is actually bolts and whoever made it welded the head of the bolt to the frame, well several fell of when I used it on the gravel or when it got hung up on roots. I think I will cut them off and weld the shaft of the bolt to the frame so they wont go anywhere. I think I will add a brace for some weights as well. Share this post Link to post Share on other sites
kaiser 100 #27 Posted April 2, 2013 i was thinking about your rake and the rake juss posted. i thought what if you used grade 8 bolts, with two nuts. drill holes across the boxed steel, then you add and subtract tines easily. Share this post Link to post Share on other sites
JUSS10 250 #28 Posted April 2, 2013 That would probably work, but you would need a bolt with really long threads to make it work if you did the bolt top down with the threads in the ground. The threads would also get beat up pretty badly. Now, if you would do the opposite (which now I'm thinking is what you meant) and cut off the bolt heads and have the "head" of the bolt in the ground and then the threads go through the frame with a nut on either side that may work. However, grade 8 bolts of that size and length would likely be a few bucks a piece and that is a lot of money stuck into the tines. For me, its just been easier to cut a new section of steel rod, cut my welds with an angle grinder then weld a new one back up. It does take more time and effort but costs much less in my case. But if you have access to bolts it would be a lot quicker change out and yeah, you have the ability to choose how many you have in contact with the ground. I like it! Justin Share this post Link to post Share on other sites
kaiser 100 #30 Posted April 2, 2013 pretty much what i was thinking, adding some cross braces and maybe a shelf like your first drawing. you're fast. lol Share this post Link to post Share on other sites
JUSS10 250 #31 Posted April 2, 2013 well i sit in front of a cad computer all day long so its pretty easy for me to quick draw something up Share this post Link to post Share on other sites
ce318 13 #32 Posted April 17, 2013 I would consider a 4x5 drag harrow the chain link style. Works great for thatching as well here in Oregon they are common and can be ordered from most farm stores about$ 200.00 new Share this post Link to post Share on other sites
woodbird007 16 #33 Posted April 23, 2013 I've been thinking about making a simple "dump rake" type dethatcher. I like the ideas that you guys discussed/shown. Hey 953, do you remember how much those tines were that you bought to make yours? Thanks, Jim Share this post Link to post Share on other sites
woodbird007 16 #34 Posted April 23, 2013 Justin, do you have any problems with yours clogging? Thanks, Jim Share this post Link to post Share on other sites
JUSS10 250 #35 Posted April 23, 2013 Well I guess it "clogs" but its a rake so it's supposed to pick stuff up so I guess I'm confused by what you are asking. If too much junk builds up I life the rake, it cleans off easy, drop it and keep going. Works quite well. I've cleared quite a bit of ivy with my rake. Share this post Link to post Share on other sites
953 nut 63,393 #36 Posted April 24, 2013 I've been thinking about making a simple "dump rake" type dethatcher. I like the ideas that you guys discussed/shown. Hey 953, do you remember how much those tines were that you bought to make yours? Thanks, Jim The tines are $3.99 each from Agri supply.com, part #33913. While you are on the site check out the belts and garden tractor parts, well priced and a good selection. I will be using the rake in the next day or two and will post a photo on this topic. Share this post Link to post Share on other sites
953 nut 63,393 #37 Posted April 27, 2013 Got out in the garden today and took a couple of photos of my home made rake, tines are from Agri Supply. The tong is 2" X 1/2" steel flat stock that I cut down to 3/8 thick to fit the slot hitch. The rest is just 2"angle iron and 1" X 1/8" flat strap. 1 Share this post Link to post Share on other sites
