Kevbo 81 #1 Posted March 24, 2013 Hi everyone my C-160 is leaking gear oil out of the axle seals. Anyone know the part number for the axle seals? Also, is it possible to replace the seals without opening the whole tranny case? Thanks! Share this post Link to post Share on other sites
pfrederi 18,592 #2 Posted March 24, 2013 (edited) 8 speed or auto???...different axle seals yes you can do it with out splitting the case. Dig it out with an ice pick 8 speed WH 100443 CR11050 Auto WH 6449 CR11124 Edited March 24, 2013 by pfrederi Share this post Link to post Share on other sites
Kevbo 81 #3 Posted March 24, 2013 8 speed thank you! Share this post Link to post Share on other sites
rmaynard 16,255 #4 Posted March 24, 2013 Toughest part is getting the hubs off of the axles. After that, it's not hard. Share this post Link to post Share on other sites
Whmaverick 54 #5 Posted March 27, 2013 Wrap masking tape around the axle and lube it before sliding the new one on. This will protect the new seal from tiny nicks that could cut the seal, don't ask me how I know. Share this post Link to post Share on other sites
doc724 925 #6 Posted March 27, 2013 Maverick, Did you emery cloth the axles before sliding the seal on? I have to do this seal replacement too and was looking for input. Also, if you wrap the masking tape around the axle, it has substantial thickness. Doesn't this make the install tight (even with lube)? Share this post Link to post Share on other sites
Trouty56 567 #7 Posted March 27, 2013 Using emory cloth should be done to remove any burrs. The use of tape...I used scotch starting from the inside out....is mainly to protect the seal from cuts at the keyway. I do the whole length and spay lubricant. The tape won't stick too well unless you really clean the axle beforehand. Share this post Link to post Share on other sites
doc724 925 #8 Posted March 27, 2013 Thanks for the tips Bob I kind of guessed that the keyway would be the culprit. I like the idea of scotch tape. What have you been using for an arbor to tap the seal into place? I have to split the transmission for a different reason, so would you recommend installing the seal before I reassemble the two halves (this must have been the procedure at the factory) or installing it after assembly and sliding the seal over the axle end? While I have it apart, I plan to install a new seal on the brake shaft-no keyway on this one! Don Share this post Link to post Share on other sites
Trouty56 567 #9 Posted March 28, 2013 I only had a trans apart once and I put the seals in when I had it apart. I still taped the axles and lubed them. It is easier to put the seals that way. When the trans is together and you put the seals in there is an appropriate sized PVC pipe you can use. I don't know the size. Don't get close to the rubber when tapping it in. I used a hub once and I think it pinched the rubber part of the seal and it leaked right away. Share this post Link to post Share on other sites
Whmaverick 54 #10 Posted March 28, 2013 Sounds like something is hanging up. Try starting it up and just try using the lift first. If the lift is erratic I'd say it's in the pump. Has the oil and filter been changed? This is why I got 2 parts tractors with hydro's in them. These sundstrands seem to be getting tired all over. If you want to test the trans in the shop jack it up and hook a belt on the pulley and run it off another tractor. Doc724, The factory uses a thin, smooth plastic shield tapered to a nipple point that slides on and off easy. I prefer installing the seal after any case work, and use a peice of PVC pipe long enough to reach the length of the axle and tap with small sledge sideways. Of course as discussed, thin wrap of tape, lapped out, and lube. Edit, Trouty56 replied as I was typing, seems we agree. LOL not sure how the above quote got in this post Share this post Link to post Share on other sites
whc160 80 #11 Posted March 28, 2013 I use emory cloth to clean the axle up. Then I wrap the axle with wax paper so it over laps a 1/4". Put some oil on the paper and install the new seal. Share this post Link to post Share on other sites
doc724 925 #12 Posted March 28, 2013 Thanks all. I am always amazed by the inventiveness and ingenuity of the RS members in problem solving! Share this post Link to post Share on other sites
608KEB 796 #13 Posted March 30, 2013 (edited) Be careful so you don't damage the needle bearings. Edited March 30, 2013 by 608KEB Share this post Link to post Share on other sites
