Shuboxlover 483 #1 Posted March 21, 2013 I see they only made them for a year. Does anyone know how many Wheel Horse made? There is one at an auction fairly close to me. I actually didn't even know they made a Raider 14 until I saw this. ~Thanks guys Share this post Link to post Share on other sites
KC9KAS 4,745 #2 Posted March 21, 2013 Looks like 1972 was the only year they were made. Model # 1-0320, 8 speed. Only WH knows how many were made! Share this post Link to post Share on other sites
Tankman 3,526 #4 Posted March 21, 2013 Raider 14 was only produced in '72. How many? As noted above, WH knows. Picture attached is my '68 Raider 12. A great "can do it all" Stallion! Decals (shown incomplete) products from www.redoyourhorse,com ~ very nice, excellent products! Product Details List (courtesy of Yahoo Groups) Model Number 1-0320 Model Year 1972 Beginning Serial None Ending Serial None Product Name Raider 14 Tractor Product Brand Wheel Horse Product Type Riding Products Product Series Garden Tractor, Pre '74 Swath Deck Optional Discharge Deck Optional Engine/Motor Manufacturer Kohler Engine/Motor Model K321S-60137A Engine/Motor Size 14 hp Engine/Motor Type 4 Cycle Engine Starter Electric Transmission Manufacturer Wheel Horse Transmission Model 5073 Transmission Speeds 8 Speed Transmission Type Gear Tractor 1972 Raider 14 1-0320 OM Download Long frame 45-1/2" wheelbase Uses 5073 8-speed transmission with 10-pinion limited slip differential and 1-1/8" axles Uses Kohler K321S-60137A with electric start, starter solenoid, 15 amp stator, ammeter and battery ignition [uses (~101917 5-terminal 4-position S-R-B-I-A) replaced by 92-6785 5-terminal 4-position S-R-B-I-L ignition switch] (PSB# 338B in the Files of Group 8 states Item 11-23 P/N not shown. The electric clutch switch is P/N 102138, same as light switch) 3 Share this post Link to post Share on other sites
CasualObserver 3,411 #5 Posted March 23, 2013 Actually WH (Toro) doesn't know how many were made. Production records from that era were lost forever between ownership changes, so unfortunately we'll never know. Member gwest has been building a serial number database for years though. via Tapatalk Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,875 #6 Posted March 23, 2013 Have recorded approximately 4600 serial numbers so far. Have recorded approximately 955 attachment serial numbers so far. That leaves approximately 3645 tractor serial numbers recorded so far for all years. There are 24 different tractor models for 1972. 1972 tractor serial numbers recorded so far is 68. Raider 14 serial numbers recorded so far is 5 manufactured in 4 batches. Garry Share this post Link to post Share on other sites
23 Reo 232 #7 Posted March 27, 2013 The serial number for my Raider 14 is 858685 if that helps. David Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,875 #8 Posted March 27, 2013 The serial number for my Raider 14 is 858685 if that helps. David They all help thanks 892204 Batch 4 892173 878605 Batch 3 858706 Batch 2 858685 858667 833053 Batch 1 Garry Share this post Link to post Share on other sites
mid60's 93 #9 Posted March 27, 2013 For what it worth: 1972 Commando 800 Ser. # 890255 1972 Raider 8 Ser. # 891677 1972 Raider 14 Ser. # 892173 Hope this helps. Larry Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,875 #10 Posted March 27, 2013 For what it worth: 1972 Commando 800 Ser. # 890255 1972 Raider 8 Ser. # 891677 1972 Raider 14 Ser. # 892173 Hope this helps. Larry Here is how these end up in the database Tractor Commando 800 4-speed 1972 890255 Tractor Raider 8 1972 891677 Vacuum Lawn 42" 1972 891978 (another owner) Tractor Raider 14 1972 892173 Have never seen a single owner with product so close together when sorted by year and serial number. Garry Share this post Link to post Share on other sites
mid60's 93 #11 Posted March 30, 2013 Garry, they are all new tractors. The Raider 14 has been started and run but never worked. The comando 800 andt the raider 8 have never had gas or a battery in them. They all came from the same place. Larry Share this post Link to post Share on other sites
jdomres66 0 #12 Posted April 10, 2013 My raider 14 is a 6 speed. Share this post Link to post Share on other sites
