rondo 0 #1 Posted August 7, 2008 Cut a small section of lawn today with the recently acquired B-100. Now, some of you know that I bought the tractor to push and pull things around because I use a different mower with a 50" cut for just mowing. But I had to see how this one does, and I'll tell ya, it's a darn nice cut. The previous owner had just sharpened the blades and it does a real good job. I will still cut sparingly since the 36" deck takes a tad longer than the 50, but it is quality seat time. Another issue, guys: Posting pics. How do I get single pics right inside the post as opposed to linking to a web site? I see some posts with the pic within and it just looks proper. Also, are there pic size limitations? Thanks, Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,834 #2 Posted August 7, 2008 Basically when you reply to a post and the post window comes up, underneath it there will be a "File Attachments" block. The limits are 1mb and 640 x 480. But, I would recommend using a host like photobucket or something similar. It appears when there are a lot of "Attached Images" using the "File Attachments" block, it slows down the thread when you try to open it up. If there are a lot of "File Attachments" a thread may take a very long time to open. This doesn't happen when you use an outside host like photobucket. B) Share this post Link to post Share on other sites
Teddy da Bear 11 #3 Posted August 7, 2008 Terry I see the limits are 56k unless Karl increased that recently. I posted a "how to" not long ago somewhere. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,834 #4 Posted August 7, 2008 Mike, Your probably right. I think Karl did change the limits to 56K. That was probably due to trying to decrease the amount of time it took to open of threads. B) Share this post Link to post Share on other sites
