ron.cieri.313 0 #1 Posted March 15, 2013 Hi all...I have a '75 Wheel Horse C-100 8-speed...getting started on restoring the deck and need to order parts but of course, I do not see any model identification number on the mower deck...here's what I know: Side discharge deck that rides directly underneath the tractor 2 larger side wheels (about 5 3/4" dia.) 5 rollers (2 3/4" dia.) Deck width...well if i don't count the part of the metal housing that serves as the shoot, i'd say 42"; longer if you count the entire housing Blades: 13 3/4" length x 2" wide; 3 of them ...what do you think? can it be ID'd from this info or do we need pics...thanks!...ron. Share this post Link to post Share on other sites
groundhog47 347 #2 Posted March 15, 2013 (edited) 5-1011 42 sd is one listed but could easily have an interchange, what type spindels, greaseable or not and are shafts doudle d or just 3/4' round. If got a 76 with a 77 retrofit spindle group. Will get back, but see if you can find the tag and a lngth on blades, 42" approx13 7/8 point to point It could also be (1) 65-42MS01 superceded modle or (2) 15-42SC03/78345 current model as shows in interchange manual here. It could also be 36" measuring blades is a good tell (1) has 3 front rollers, 4 rear rollers, 2 adj wheels, double d shafts and pulleys and solid belt cover originally per Toro diagram (2) has three front rollers, two back rollers and two adj wheels, belt guard is two piece and mounts on a removeable deck reinforcement plate and round spindel shafts appear unkeyed per Toro parts diagram Can't locate 5-1011 drawing Edited March 15, 2013 by groundhog47 Share this post Link to post Share on other sites
Sparky-(Admin) 23,526 #3 Posted March 15, 2013 If its original it would be this one. I copied this off the TORO site. 5-1011 42" Side Discharge Mower Current Model Available: 15-42SC03/78345 Original Model Supersedes To: 65-42MS01 Mike.................. Share this post Link to post Share on other sites
KATO 115 #4 Posted March 15, 2013 (edited) here's a link to part's and drawing of 5-1011 deck http://www.partstree.com/parts/?lc=toro+consumer&mn=5-1011 Edited March 15, 2013 by KATO Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,604 #5 Posted March 16, 2013 The Toro site is good but misses many of the models between those listed 5-1011 [V spindle greaseable metric] replaces [X spindle greaseable standard] replaces [K spindle non-greaseable] Replaces RL-426, 5-1421, 5-1422, 5-1423, 5-1000, 5-1001, 5-1010 Replaced by 5-1012, 65-42MS01, 65-42MS02, 75-42MS01, 75-42MS02, 85-42MS01, 95-42MS00, 95-42MS01, 05-42MS01, 05-42MS02, 05-42MS03, 05-42MS04, 05-42MS05, 15-42SC01, 15-42SC02, 15-42SC03/78345 To identify the spindles Garry Share this post Link to post Share on other sites
ron.cieri.313 0 #6 Posted March 16, 2013 Thanks everyone...that sure looks like the one...appreciate the help...ron Share this post Link to post Share on other sites
Forest Road 594 #7 Posted March 20, 2013 I have a full set of used spindles. PM me for info Share this post Link to post Share on other sites
