chevyaddict83 39 #1 Posted March 14, 2013 Anyone have any pictures of how a plow mounts on to an 855? I have a plow, and an 855. I would like to know whats missing Sent from my 416-8 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,467 #2 Posted March 14, 2013 Your blade should be one of these to fit BD-4264A (Complete blade) Replaced by BD-4267, 6-2111, 6-4111, [6-4112 & 6-9621], [6-4113 & 6-9622], [6-4113 & 6-9623], [6-4114 & 6-9624], 6-2131, 6-2132, 6-2133, 66-42BC01, 76-42BC01, 86-42BC01, 96-42BC01, 06-42BC01, 06-42BC02, 06-48BC01, 06-48BC02, 06-48BC03, 79350 and 79364 The early ones fit the short frame tractors and then starting with the 6-4111 they will fit both the long and short tractor frame models. Go into the manuals here and do a search using 4264A to see the manual for the 1965 blade. You can search others also but use just the numbers after the dash in the model number when searching. Garry Share this post Link to post Share on other sites
chevyaddict83 39 #3 Posted March 14, 2013 (edited) From the pictures, it looks the same as the later model one for the roto tiller and plow assembly. Sent from my 416-8 Edited March 14, 2013 by chevyaddict83 Share this post Link to post Share on other sites
JimmyJam 542 #4 Posted March 15, 2013 Where are the pictures? Share this post Link to post Share on other sites
chevyaddict83 39 #5 Posted March 15, 2013 On parts tree, jimmy. Happy friday! Sent from my 416-8 Share this post Link to post Share on other sites
Kelly 1,038 #6 Posted March 15, 2013 The 855 uses the old style plow bracket, it bolts in front of the axle, not under it like the newer tractors, I can get pics this weekend if you need them. Share this post Link to post Share on other sites
chevyaddict83 39 #7 Posted March 15, 2013 That would be great! Thanks kelly! Share this post Link to post Share on other sites
Kelly 1,038 #8 Posted March 18, 2013 I had to find this tread again , these are not great pics tractor is a bit rusty, but it is a 655 pretty much same as your tractor, you can see the early mount goes in front of the axle, unlike the newer mount that goes under the axle. Share this post Link to post Share on other sites
