Machria 77 #1 Posted March 11, 2013 Ok, the snow is over, I think. I want to take off the snow blower from my new GT14. So I looked at it last night, how do I get the belt off the motor pulley? Do I have to take somethin apart? Thanks in advance! Share this post Link to post Share on other sites
Machria 77 #2 Posted March 11, 2013 I want to also add, what belt is this and where do I get a spare? I'd like to keep a spare just in case! Thanks Share this post Link to post Share on other sites
855ownerJoel 32 #3 Posted March 11, 2013 I cannot help you, since I do not have one with an electric pto clutch. But regarding the belt just take it to an automotive shop while it is still good and they can measure it. Make sure you tell them what it is for so they give you a belt that will handle the snow blower application. Some people call them I believe a special duty belt. Share this post Link to post Share on other sites
TT-(Moderator) 1,128 #4 Posted March 11, 2013 Unplug the connector on the clutch wiring. (orange) Remove the hitch pin clip (#17) from the clevis pin (#16)and remove the clevis pin from the clutch tab and the stop bracket. (#14) Rotate the clutch "face" in either direction to allow the belt to be removed. Rotating the thrower drive belt tensioner assembly against the tension of the spring should allow enough slack to remove the belt. Share this post Link to post Share on other sites
Machria 77 #5 Posted March 11, 2013 Perfect! thanks so much! Share this post Link to post Share on other sites
Butch 194 #6 Posted March 12, 2013 TT's the man ain't he!! Perfect! thanks so much! Share this post Link to post Share on other sites
