Wheelhorse84 87 #1 Posted February 27, 2013 So my new 416 while the front wheels are straight the steering wheel is turned like this. How do I make my wheel straight? Share this post Link to post Share on other sites
ericj 1,579 #2 Posted February 27, 2013 i would pull the tower loose and reset the steering wheel and then fine tune with tire rods some body might come along with a better idea though eric j Share this post Link to post Share on other sites
squonk 46,172 #3 Posted February 27, 2013 Check the block on the frame where the steering shaft goes in for cracks. Very common. Share this post Link to post Share on other sites
WH854 45 #4 Posted February 27, 2013 (edited) So my new 416 while the front wheels are straight the steering wheel is turned like this. How do I make my wheel straight? ImageUploadedByTapatalk1361999860.269885.jpg There is a collar with a set screw you can losen and adjust the steering wheel with. Chas Or put your Model# here and look under front axle and steering. https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro Chas Edited February 27, 2013 by WH854 Share this post Link to post Share on other sites
can whlvr 994 #5 Posted February 28, 2013 like chas said,under the hood look at the steering shaft,you will see a lock collar with a set screw,loosen off the collar,and then pull the steering wheel up a little to lift it out of the lower block,turn the wheel to where you want it,make sure the wheels are straight and push it back down,slide the collar up and tighten the set screw,check for broken sheet metal around the shaft,its a common problem Share this post Link to post Share on other sites
