Shuboxlover
Everyone's FAVORITE game show...
Shuboxlover
Let's play....
NAME THOSE PARTS!!!!!!!!!!!!!!
Picked up these parts tonight, most are NOS a couple are lightly used, I know what some of them are, some of them i don't, and some of them might not even be Wheel Horse.  Nonetheless, I would GREATLY appreciate if you guys would take the time to identify what exactly I have here and what tractors they fit....
THANKS!!!!!!!!!!!!!!!
photobucket-5539-1361849590106_zps3988de
photobucket-5230-1361849589542_zps6bea74
photobucket-5354-1361849589972_zpsed50ef
photobucket-5538-1361849589912_zps084f18
photobucket-5162-1361849590278_zps9b324f
NOS 3-PT.
photobucket-5156-1361849589774_zpsf2550b
photobucket-5519-1361849589714_zpsdaebdc
photobucket-5318-1361849590452_zpsc02bd4
photobucket-5321-1361849589776_zps867893
photobucket-5525-1361849589776_zpsb02f7a
squonk
 J is a slot hitch tow bar, H is a clevis hitch, I is a clevis hitch plate, K is a front axle to frame pivot pin,C is a mile drive pulley mount for like an Electro and that vintage, G tie rods, B, clutch PTO disc A, steering spindles.
JimD
A. WH front axle spindles, B. WH pto clutch disc, D. WH front tach-a-matic lock, E. WH mule drive pulley, G. WH steering tie rods, H. WH clevis hitch, N. WH pto bell pulley, S. top link for 3pt hitch.
SousaKerry
L and o have me curious what does the sticker say P is top link mount for 3 point
Edited by Sousakerry2
Brrly1
Ok, before I use my infinite wisdom is any of this for sale?
Shuboxlover
The stickers says....
     RUN
R          C
O          L
T          U
O          T
R          C
             H
  STOP
And it's made of plastic
And Burly......I'm sure some of this will be for sale, Whatever I don't have a use for will be let go.
Don1977
"D" is the latch part of mid mount Tack-A-Matic. The latch lever on the front is 2" from the other side welded on the rod. I believe "N" is D Series PTO pulley D-160, D-180, and D-200.
squonk
Keep that axle pivot pin. (K) You may need it someday.
CasualObserver
L is the belt guard from a Trailblazer.  you can still buy it new for about $20-25.  It goes between the power unit and the snow blower over the pto clutch lever.
K looks to me like the little piece that the late 60s mower deck belt tensioner control arm connects to, so it would go with part C which is another part of that tensioner and flat pulley E.  Here's the partial diagram of the 5-1422 showing them.
Shynon
T looks like it goes to the 3 point set up for a GT14. It connects the rockshaft to the 3 point lift. R could be from the rockshaft to the implement (push blade) on  a GT14 . S is the upper link for 3 point.
Tom
Shuboxlover
Does anyone know what the 3pt. setup is for....it is a GT14...or????
refracman
M- 1969 1/2 thru 1973 GT14 lower 3pt hitch( will fit 1969- 1973),
T 1969-1973 gt14 mid rock shaft to 3pt rock shaft connecting linkage
O- is a gear reduction box, for what I want to know!
Shuboxlover
Thanks Refracman!!!!!!!
Is part "P" a piece for a GT14 3pt. also???
refracman
No its not, looks to be for a LT or a attachment same with Q and R
just came to me I think R is for a vertical shaft like a mid 80s 215 snow plow
wh500special
O looks like the transmission from a Trailblazer snow blower or from one of the rear engine riders.
Q is a bracket for attaching a grass catcher back to the goofy 32" SD deck used on the vertical shaft rangers and A-series.
Brrly1
Three point set-up is for a "D" series
Shynon
Burly how can you tell it is  a 3point for D series? What gives it away? I see you have a 3 point, could you post pics please? I am planning on 3pt on one of my GT14's, have most parts to make it independent lift, will need to make the arms.
 Thanks Tom
wh500special
John,
That's a GT14 hitch.  The D-auto hitch doesn't come with any additional bracketry for the draft (lower) links.  Note on the port/left side of the hitch the mounting provision for the optional lift cylinder.  You had two options with the GT14 to lift the hitch:  USe the long bracket (T) to connect the hitch rockshaft to the main rockshaft, or install a lift cylinder on the hitch itself and a second control valve connected in series with the main control valve.
Steve
