Shuboxlover 481 #1 Posted February 26, 2013 Let's play.... NAME THOSE PARTS!!!!!!!!!!!!!! Picked up these parts tonight, most are NOS a couple are lightly used, I know what some of them are, some of them i don't, and some of them might not even be Wheel Horse. Nonetheless, I would GREATLY appreciate if you guys would take the time to identify what exactly I have here and what tractors they fit.... THANKS!!!!!!!!!!!!!!! NOS 3-PT. 1 Share this post Link to post Share on other sites
squonk 43,911 #2 Posted February 26, 2013 J is a slot hitch tow bar, H is a clevis hitch, I is a clevis hitch plate, K is a front axle to frame pivot pin,C is a mile drive pulley mount for like an Electro and that vintage, G tie rods, B, clutch PTO disc A, steering spindles. Share this post Link to post Share on other sites
JimD 3,347 #3 Posted February 26, 2013 A. WH front axle spindles, B. WH pto clutch disc, D. WH front tach-a-matic lock, E. WH mule drive pulley, G. WH steering tie rods, H. WH clevis hitch, N. WH pto bell pulley, S. top link for 3pt hitch. Share this post Link to post Share on other sites
SousaKerry 503 #4 Posted February 26, 2013 (edited) L and o have me curious what does the sticker say P is top link mount for 3 point Edited February 26, 2013 by Sousakerry2 Share this post Link to post Share on other sites
Brrly1 1,146 #5 Posted February 26, 2013 Ok, before I use my infinite wisdom is any of this for sale? 1 Share this post Link to post Share on other sites
Shuboxlover 481 #6 Posted February 26, 2013 The stickers says.... RUN R C O L T U O T R C H STOP And it's made of plastic And Burly......I'm sure some of this will be for sale, Whatever I don't have a use for will be let go. Share this post Link to post Share on other sites
Don1977 605 #7 Posted February 26, 2013 "D" is the latch part of mid mount Tack-A-Matic. The latch lever on the front is 2" from the other side welded on the rod. I believe "N" is D Series PTO pulley D-160, D-180, and D-200. Share this post Link to post Share on other sites
squonk 43,911 #8 Posted February 26, 2013 Keep that axle pivot pin. (K) You may need it someday. Share this post Link to post Share on other sites
CasualObserver 3,411 #9 Posted February 26, 2013 L is the belt guard from a Trailblazer. you can still buy it new for about $20-25. It goes between the power unit and the snow blower over the pto clutch lever. K looks to me like the little piece that the late 60s mower deck belt tensioner control arm connects to, so it would go with part C which is another part of that tensioner and flat pulley E. Here's the partial diagram of the 5-1422 showing them. Share this post Link to post Share on other sites
Shynon 7,482 #10 Posted February 26, 2013 T looks like it goes to the 3 point set up for a GT14. It connects the rockshaft to the 3 point lift. R could be from the rockshaft to the implement (push blade) on a GT14 . S is the upper link for 3 point. Tom Share this post Link to post Share on other sites
Shuboxlover 481 #11 Posted February 28, 2013 Does anyone know what the 3pt. setup is for....it is a GT14...or???? Share this post Link to post Share on other sites
refracman 167 #12 Posted February 28, 2013 M- 1969 1/2 thru 1973 GT14 lower 3pt hitch( will fit 1969- 1973), T 1969-1973 gt14 mid rock shaft to 3pt rock shaft connecting linkage O- is a gear reduction box, for what I want to know! Share this post Link to post Share on other sites
Shuboxlover 481 #13 Posted February 28, 2013 Thanks Refracman!!!!!!! Is part "P" a piece for a GT14 3pt. also??? Share this post Link to post Share on other sites
refracman 167 #14 Posted February 28, 2013 No its not, looks to be for a LT or a attachment same with Q and R just came to me I think R is for a vertical shaft like a mid 80s 215 snow plow Share this post Link to post Share on other sites
wh500special 2,277 #15 Posted February 28, 2013 O looks like the transmission from a Trailblazer snow blower or from one of the rear engine riders. Q is a bracket for attaching a grass catcher back to the goofy 32" SD deck used on the vertical shaft rangers and A-series. Share this post Link to post Share on other sites
Brrly1 1,146 #16 Posted February 28, 2013 Three point set-up is for a "D" series Share this post Link to post Share on other sites
Shynon 7,482 #17 Posted February 28, 2013 Burly how can you tell it is a 3point for D series? What gives it away? I see you have a 3 point, could you post pics please? I am planning on 3pt on one of my GT14's, have most parts to make it independent lift, will need to make the arms. Thanks Tom Share this post Link to post Share on other sites
wh500special 2,277 #18 Posted February 28, 2013 John, That's a GT14 hitch. The D-auto hitch doesn't come with any additional bracketry for the draft (lower) links. Note on the port/left side of the hitch the mounting provision for the optional lift cylinder. You had two options with the GT14 to lift the hitch: USe the long bracket (T) to connect the hitch rockshaft to the main rockshaft, or install a lift cylinder on the hitch itself and a second control valve connected in series with the main control valve. Steve Share this post Link to post Share on other sites
