Dieselcowboy 211 #1 Posted February 25, 2013 Would anyone happen to have ever found a source of the carb rebuilding parts for an H55B on a suburban 550? Or is there a suitable replacement that might fit decently? I had my 550 running on almost full choke so I took to carb off and cleaned it in chem dip, now I cannot get it to do anything more than pop and fire a few times in a row. The engine did sound really good before... Share this post Link to post Share on other sites
specialwheelhorse 174 #2 Posted February 25, 2013 The last I knew Tulsaenginewarehouse had new after market carbs for Tecke's for around fifty bucks. You really can't rebuild one for much less and at that you still have an iffy carb. Jim In Texas Share this post Link to post Share on other sites
Dieselcowboy 211 #3 Posted February 25, 2013 This has an Updraft Tillison carb on it now. Clearance issues so I have read. Share this post Link to post Share on other sites
puddlejumper 67 #4 Posted February 26, 2013 I think Joe papke reproduces them, but not for sure. Try another trip through the chemdip and blower out real good again,sound like you broke some crude loose but it didn't get completely clear. Share this post Link to post Share on other sites
Dieselcowboy 211 #5 Posted February 26, 2013 There is really not much to go wrong with these is there? Most simple carb I think I have ever seen. Share this post Link to post Share on other sites
puddlejumper 67 #6 Posted February 26, 2013 What kind of shape is the throttle shaft in. that could explain the need for choke if its really loose. Share this post Link to post Share on other sites
Dieselcowboy 211 #7 Posted February 26, 2013 It does seem a little loose. Seems to have a flood like condition where gas drips from bottom of carb very quickly if I choke too much and gas wets around the throttle shaft too. Share this post Link to post Share on other sites
puddlejumper 67 #8 Posted February 26, 2013 Somebody else will chime in I am sure, but when you put it back together you may have got your float set to high. I think I would tear it back down and soak it overnight (at least) blow it out with a air gun or a can of carbcleaner with a straw so you can force a flow through all the orifices and see what happens. AND USE A NEW MOUNTING GASKET Share this post Link to post Share on other sites
