mike66 2 #1 Posted February 24, 2013 Hi i have a 12 horse tractor with a Hydrogear mod #90-2046 trans. I purshased a hyd lift for it and installed but have no pressure on the lines. I have the lines in the correct ports does anyone have an idea what many be wrong . Thanks Mike Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted February 24, 2013 Welcome to Red Square. You do need to add a valve assembly in one of the ports. I've never done it, but there are some threads on here describing it. I'll see if I can find some of them. Share this post Link to post Share on other sites
Trouty56 568 #3 Posted February 24, 2013 In the hydrogear a cone and spring need to be installed in the front of the pump.....If you follow the one hose above from the rear over top of the pump to the front, at about that point is a cap with maybe a 3/4" bolt head on it. The cone and spring would fit under it. Share this post Link to post Share on other sites
mike66 2 #4 Posted February 25, 2013 Thanks guys now all i need to do is find some where to purchase the parts needed you have been a great help . Mike Share this post Link to post Share on other sites
sorekiwi 761 #5 Posted February 26, 2013 Try this post: Share this post Link to post Share on other sites
mike66 2 #6 Posted February 26, 2013 Got it up and going tonight thanks everyone 2 Share this post Link to post Share on other sites
