Mr. 856 170 #1 Posted February 20, 2013 So I have one little washer left over after I installed my governor gear and cross shaft. I think It is supposed to go on the cross shaft(thinner end). Im assuming it would then end up inside the engine up against the brassscrew once you screw the brass thing in? Im also supposed to have a washer under the governor gear itself to ride on the stub. right? I broke rule #1. Never took pictures of how the governor came apart. Photobucket seems to not be working so I have pictures. Only washers manual speaks of are on governor gear stub and one on the gear stop screw. I have both those installed. Last little washer is missing a home. Can anyone help? Share this post Link to post Share on other sites
rmaynard 16,543 #2 Posted February 20, 2013 Why not just upload your pictures directly to your post and forget Photobucket. There should be a thrust washer behind the governor gear. The other washer I'm not sure of. Pictures would help. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #3 Posted February 20, 2013 Cross shaft / spacer / washer / brass bushing nut. Share this post Link to post Share on other sites
buckrancher 2,695 #4 Posted February 20, 2013 (edited) the thin washer with the 3/8" hole goes behind the gov. gear the small washer with 3/16"- 1/4" hole goes on the cross shaft behind the brass nut Brian Edited February 20, 2013 by buckrancher Share this post Link to post Share on other sites
Mr. 856 170 #5 Posted February 20, 2013 Ahh it was the little washer that goes on the cross shaft. Thanks for the help. Share this post Link to post Share on other sites
