welderman85 53 #1 Posted February 19, 2013 is it safe to use on our tractors Share this post Link to post Share on other sites
roscoemi 245 #2 Posted February 19, 2013 Very sparingly. It will shuck the oil off the rings and may detonate and knock the rod bearings out. Very little, very careful! Share this post Link to post Share on other sites
Kelly 1,038 #3 Posted February 19, 2013 I don't use it, I use brake cleaner, or carb cleaner much more friendly on small engines, I can run a engine with out a carb even bolted on with just the right mist of brake cleaner, in the intake port, done it many times. Share this post Link to post Share on other sites
zeedubbya 18 #4 Posted February 19, 2013 Was warned by a wise old JD collector (hmmmm..) one time to use carb cleaner. If starting fluid is the only option use very very sparingly for the exact reasons roscoemi said above. Share this post Link to post Share on other sites
specialwheelhorse 174 #5 Posted February 19, 2013 I have rebuilt many engines in my liftime and you couldn't pay me enough to use SF If an engine is set up right and won't run on a fine mist of the fuel it is designed for there is something drasticly wrong. 1 Share this post Link to post Share on other sites
MalMac 1,335 #6 Posted February 19, 2013 I personally would not do it. I have seen big diesels get damaged from it let alone putting an actual spark to it. It's really a good way to get hurt or damage an engine in my opinion. Share this post Link to post Share on other sites
Sparky-(Admin) 24,872 #7 Posted February 19, 2013 So educate me guys....what is starting fluid actually supposed to be for? Mike.............. Share this post Link to post Share on other sites
roscoemi 245 #8 Posted February 19, 2013 Blowin stuff up !!! It can be used, but be careful. Other than that, cleanining old grease off parts. 1 Share this post Link to post Share on other sites
MalMac 1,335 #9 Posted February 19, 2013 It is to aid in starting Diesel engines. Even then it has to be used correctly or damage can occur. Diesels that have glow-plugs in them is a big no no. Either is so flammable and explosive that when contained in a small confined area like the cylinder of a small gas engine and you put a spark to it you can get a really big bang! Diesel because of no spark and lot thicker heads and cylinder walls can sustain the ignition of either if used right. Not much more I can say under the best circumstances it can be dangerous. I have used it a lot on big equipment in the dead of winter and have seen the benefits and the down side of it. Share this post Link to post Share on other sites
wallfish 19,544 #10 Posted February 19, 2013 I had a full can puncture in the back of my van while on the highway. By the time I realized what was going on, opened the windows and pulled over, I was dizzy enough to fail a sobriety test. Kind of funny now but it wasn't at the time. I used it for old crappy pull start push mowers. We used to spray it into our gas for mopeds when we were kids to try and give them a boost. Share this post Link to post Share on other sites
MalMac 1,335 #11 Posted February 19, 2013 Wallfish sounds familiar, I was driving a semi coming out of Chicago on a very rough part of the hi-way when a can of starting fluid got loose and was rolling around. I could not reach down and grab it. It roll right under the air ride seat and all the up and down motion it finale got caught and the top got smashed off it buy one of the large bounce I took. Time I got the truck pulled over I was in another world. Like you said funny now but lucky I did not pass out or blow up. Learned my lesson. Put that can in the tool box not in the cab. Share this post Link to post Share on other sites
Wheel-N-It 2,978 #12 Posted February 19, 2013 Use carb cleaner. SF will work, but I would not recommend it. Share this post Link to post Share on other sites
otrelwood 32 #13 Posted February 19, 2013 (edited) i use wd40 its flammable plus oily enough to lubricate the cylinder Edited February 19, 2013 by otrelwood Share this post Link to post Share on other sites
oldredrider 2,553 #14 Posted February 21, 2013 I use it on my 10hp Tecumseh. Have for years. I hate that motor and it just won't die! Share this post Link to post Share on other sites
can whlvr 994 #15 Posted February 22, 2013 blew the entire front end off of my 1997 f 450 cubevan,even destroyed the grill,we were lucky to not get hurt using starter fluid Share this post Link to post Share on other sites
