dsholler 54 #1 Posted February 12, 2013 Please forgive me, but I am sure this question has been answered a zillion times here, but I cannot seem to locate it . My starter sounds like it is turning, but the engine does not crank . I can turn the flywheel by hand, but no movement at all when I engage the starter. I am a rather inexperienced mechanic, and it was suggested to me that the bendix might be stuck. This started after a day of blowing snow and getting wet. So the question is how the heck do I get at it? I have some graphite powder lube, that I thought might help, but there did not seem to be any way to get the starter out? Do I have to take off the oil tube? Can I take the shield off the flywheel side and get at it that way? Is there a simpler way to determine if this is really what is going on before I start taking things apart? Oh, it is a 87 414 with the original Kohler Magnum 14 in it Share this post Link to post Share on other sites
meadowfield 2,955 #2 Posted February 12, 2013 It could be either the bendix that is stuck or water in the damper/friction cone. I've had both... A hammer or screwdriver is not the solution. Simply unbolt the starter and take the clip/spring/pinion apart and clean, applying a small amount of grease to the helix on the starter end before reassembling.... I'm guessing others will chip in too!! Mark Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #3 Posted February 12, 2013 Because of how they are mounted, I think it's easier to access the starter drive on a Magnum single by removing the blower housing. (flywheel cover) :confusion-shrug: Share this post Link to post Share on other sites
squonk 45,806 #4 Posted February 12, 2013 Yeah,take off the housing and lube he shaft where the gear slides. I had a Tecky on a blower that was rusted stuck real bad. A little pentrant and a little soaking time and it was free. Share this post Link to post Share on other sites
dsholler 54 #5 Posted February 13, 2013 Thanks all. Headed out of town for a biz trip, but will see if I can tackle it this weekend. Share this post Link to post Share on other sites
dsholler 54 #6 Posted February 16, 2013 Ok. Gear was not traveling at all. Spun it around and it is now freed and working. Question is how to lube it. I put some graphite powder on it, but others on here have suggested grease. What would you use? Share this post Link to post Share on other sites
puddlejumper 67 #7 Posted February 18, 2013 I have always used a small amount of grease, BUT I think a dry lubricant such as graphite is actually recommended. Share this post Link to post Share on other sites
