Raider12
GT-14 Anyone have one?
Raider12
I have seen a few of the GT-14 tractors over the summer. And from the looks these are a bigger chassie than those such as my Raidar 12 and similar models. Are do these tractors stack up against the rest? Anyone have one that can share some input? Thanks
WheelHorse_of_course
:whistle: I Have never seen one, but it was the first "bigger" tractor WH made. Bigger than what? Bigger in terms of features versus the C series (or its predecessors) , for example.
I await the opportunity to learn more B) B)
refracman
I am a lttle partial to the GT14. It was Wheel Horses first true large tractor.
It was and still is a very capable piece of equipment. Although it does have a few qwirks mostly the hydro control( harder than the rest to use) and a large turning radius, and the orginal muffler tended to melt the gas tank B) . In my opinion more durable than the D's ( fewer mechanicial problems) and with it size more capable the the C's exept the C195.
Once you own one of these beasts you"ll understand what I mean. I currently have 4 GT14's a 195 and 2 160's.( and yes I've had a D)The loader GT14 gets the most use of all them.
Truely a great tractor!
Brrly1
Yeah, Yeah, What Steve said GT14's rule!!! Burly
B):whistle:B) :horseplay: :horseplay: :horseplay:
rustbucket
i have one and it is a beast dry weight from factory was 980 pounds if i recall and it has a 6 gallon gas tank in the nose as well the whole nose ferring is cast iorn and heavy. the machine uses a kohler K series 14 hp as well the dash is cast iorn and it is all together a beast of a machine. was one of a very few tractors wheel horse made a 52 inch plow for if i recall also.
Teddy da Bear
I just got one today!
Still looking for answers in my post too!
Brrly1
Hey Teddy You just got one answer of many that are sure to follow! Burly B) :horseplay:
Teddy da Bear
Thanks John.....I knew I could count on ya and your GT-14 knowledge.
Brrly1
Teddy, There's not much there my friend as I am just learning. I look to my buddies Steve (Refracman) and our good friend Carl who has been wrenching on these machines since the late 60's. Good Luck Burly B) :whistle:
tookies
I have a GT-14 that I am restoring and a 520HC to compare it to. The GT-14 is a monster in that it has a cast iron nose, large tires (rear) and a true cat "0" hitch system. The amount of metal WH used on them is incredible and makes the GT-14 worthy of restoration. I like that even in 73 WH had a fan on the Hydro and a filter on the tranny. On top of it all my GT-14 seems bigger than than my 520 HC and handles more like a tractor than the HC. Truly a unique machine!
rustbucket
these machines are fun to run and the rears are 15's you can run car tires if ya have too but why.
