gogolito 0 #1 Posted February 11, 2013 I every body. So my hydro was leaking from drain plug and after replace it it doest work at all. Was running before very strange. I try to bleed it but find nothing to do it. Any help please Share this post Link to post Share on other sites
refracman 167 #2 Posted February 11, 2013 Did you drain the trans or the hydro? On the 516 they are seperate and each have their own fluids. And the hydro is nonserviceable in most cases. Share this post Link to post Share on other sites
gogolito 0 #3 Posted February 12, 2013 Yeah the hydro trans. Leaking from drain plug And after replace it oil dont go in so, too much air but cant bleed it Share this post Link to post Share on other sites
ericj 1,580 #4 Posted February 12, 2013 did you add through the dip stick or the reservoir make sure you are adding oil to the part of the trans you drained out. did it make any noise and did it run ok before you drained the oil eric j Share this post Link to post Share on other sites
