gogolito
Wheel horse 516H hydro problem
gogolito
I every body.
So my hydro was leaking from drain plug and after replace it it doest work at all. Was running before very strange. I try to bleed it but find nothing to do it.
Any help please
refracman
Did you drain the trans or the hydro?
On the 516 they are seperate and each have their own fluids. And the hydro is nonserviceable in most cases.
gogolito
Yeah the hydro trans. Leaking from drain plug
And after replace it oil dont go in so, too much air but cant bleed it
ericj
did you add through the dip stick or the reservoir make sure you are adding oil to the part of the trans you drained out. did it make any noise and did it run ok before you drained the oil
eric j
