jeremi3210 742 #1 Posted February 10, 2013 What is the best way to remove a 1533 bearing without wrecking it? Share this post Link to post Share on other sites
WH854 45 #2 Posted February 10, 2013 What is the best way to remove a 1533 bearing without wrecking it? Slide Hammer Pilot Bearing Remover Chas Share this post Link to post Share on other sites
sorekiwi 761 #3 Posted February 11, 2013 I normally use a small slide hammer with 2 jaws on the end of it. I think I have also knocked them out with a long drift down through the axle tube. Keep in mind that it is not very good practice to remove them this way, by hitting them on the inner race (while the outer race is tight in the housing) you run the risk of putting a small flat spot on the balls or in the races. But it is unavoidable in this case. Share this post Link to post Share on other sites
stevasaurus 23,418 #4 Posted February 11, 2013 I have had success using a pneumatic hammer with a sharp spade bit...popped them right out with no damage. :) Share this post Link to post Share on other sites
