rwilson 128 #1 Posted February 8, 2013 I have a c175 with a series 1 kt17. last time i was plowing snow around half throttle the lights kept getting dimmer. It wasnt charging. I replaced the voltage regulator and it is now charging 17.01 to 17.05 vdc idleing and 17.84 to 17.88 vdc at full throtle. that is tested at the batery. Is that too much? what could be wrong? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted February 8, 2013 What is the AC output at the stator leads? (disconnected from the R/R & engine at wide open throttle) Is the R/R grounded properly? If it's questionable, run a dedicated ground wire between it and the battery negative terminal - at least for a test. Share this post Link to post Share on other sites
rwilson 128 #3 Posted February 8, 2013 I'll check it out tomorrow. Share this post Link to post Share on other sites
Wheel-N-It 2,976 #4 Posted February 8, 2013 I keep a ground jumper between the regulator and negative side of the battery on my KT-17 series 2. Share this post Link to post Share on other sites
Save Old Iron 1,571 #5 Posted February 8, 2013 You're in good hands so far. As a time saving step, I will say if the charge voltage is TOO HIGH, you can assume the AC output from the stator is OK. Considering the RR unit chops half the AC voltage away to convert to DC, you can assume you have at least 35 volts AC from the stator and the stator is OK. 35 / 2 = 17.5 which is what you are seeing from the RR unit. And then there are some small losses in the RR unit so I believe you will find the AC voltage at or above 36 VAC. Share this post Link to post Share on other sites
meadowfield 2,758 #6 Posted February 8, 2013 Those voltages are too high though, 13.8 -14.4 is the sweet spot, for 30 mins on a non sealed battery you are safe at 15v. I wouldn't want to be running that high for too long.... Sounds like r/r is regulating and working, but set too high. Either the ground to the PCB is poor or the Zener reference diode (if fitted with one) is shot. Mark Share this post Link to post Share on other sites
rwilson 128 #7 Posted February 8, 2013 thanks for all the input. I'm going to check the AC voltage in a bit and will let everyone know what the magic number is. I dont mind it at 17 volts. My headlights are nice and bright!! Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #8 Posted February 8, 2013 Hey Rich..... Reminder: Make sure the terminals are clean on the R/R & connector, along with the ignition switch and amp gauge terminals and connectors. The resistance from corrosion can fool the R/R into thinking the battery voltage is lower than it actually is. Share this post Link to post Share on other sites
rwilson 128 #9 Posted February 8, 2013 ok i'll make sure its clean. i'm heading out in a few minuits to check it out. Share this post Link to post Share on other sites
rwilson 128 #10 Posted February 9, 2013 ok got good ground. took the plug off the RR and found one bad wire end. fixed that checked the voltage out of the stater and got 24ish. cleaned all my plug ins and now its charging 14.4 to 14.6 at the batery. so I guess i found and fixed my problem. 1 Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #11 Posted February 9, 2013 now its charging 14.4 to 14.6 at the batery. Perfect! :handgestures-thumbup: Share this post Link to post Share on other sites
Save Old Iron 1,571 #12 Posted February 9, 2013 checked the voltage out of the stater and got 24ish When you measure the stator output, measure on the AC volts scale of the multimeter with the meter leads attached directly across the AC terminals of the RR unit or if the stator leads are off the RR unit, place one meter lead on each stator lead. When measuring the stator output, DO NOT MEASURE TO GROUND - THE MULTIMETER LEADS GO DIRECTLY TO THE STATOR WIRES. I believe in your case, the AC voltage would be about double what you measured and would have been over 40 volts AC. And that's a good thing If you told someone your stator output was 24 volts, and they assumed you had the meter hooked up properly, they would have advised you the stator was defective. Share this post Link to post Share on other sites
