meadowfield 2,740 #51 Posted April 24, 2013 George, what's the number on the Amnor plate that you removed? that's the one we need to ID it by. thanks mark Share this post Link to post Share on other sites
Chips1953 0 #52 Posted April 24, 2013 (edited) I have the plate with me now and it's telling me that the Model is :1-3742 and it's Serial is : 116598. The Kohler engine is a K161 T Ser No E0174073 and the Spec. No. is 28937J Hope this helps. I'll just do the photos now. Thanks. Edited April 24, 2013 by Chips1953 Share this post Link to post Share on other sites
meadowfield 2,740 #53 Posted April 24, 2013 cool, so the number ties up with my database. engine doesn't tie up tho' - but then I had made up the engine as I never enquired that detail with the customer... Going to update the database tonight with k161. btw I thought yours was the earlier commando 7 decal set? the pictures show the later decals. mark Share this post Link to post Share on other sites
Anglo Traction 761 #54 Posted April 24, 2013 The Tractor and the K161 are 1969, and yes George, it had a vacuum Fuel pump on it (suspect there maybe no Pump Cam on the Camshaft) . Don't see many around, but one could be adapted from a Mechanical Pump if you get desperate.........nice little Tractor......good luck with the Refurb. Share this post Link to post Share on other sites
meadowfield 2,740 #55 Posted April 24, 2013 Many thanks to you both. The dash has a hole for "Ignition", "Lighter" and lights. So it must have had a battery at one stage. Yes? George. Many of the early models had these cutouts with nothing fitted. The Geel factory very often made things fit.... Share this post Link to post Share on other sites
Chips1953 0 #56 Posted April 24, 2013 The Tractor and the K161 are 1969, and yes George, it had a vacuum Fuel pump on it (suspect there maybe no Pump Cam on the Camshaft) . Don't see many around, but one could be adapted from a Mechanical Pump if you get desperate.........nice little Tractor......good luck with the Refurb. Thanks for all this info. The tractor is now prepped for paint. The cover over the cam must be where the original pump was situated. If it was a vacuum pump I should be able to make a new cover to allow me to use an after market device. I also need to make points cover. It's been a few days of constant work, so can't wait to start the assembly. I have a litre of Post Office 2 Pack Red, which I'm going to use. I want to be able to wash her down when she's done her work, so I'll lay it on thick. When I've finished I'll put a few photos up. Once again thanks for all your support, I'll keep in touch. Share this post Link to post Share on other sites
Stormin 9,984 #57 Posted April 24, 2013 The rate your going George, you'll have it up and running by next weekend. If you do, I can get you a late entry for the Hethersgill Rally. Share this post Link to post Share on other sites
meadowfield 2,740 #58 Posted July 10, 2013 I'll be at Ardingly taking submissions to the exclusive uk wheel horse register.... With a new sticker too Share this post Link to post Share on other sites
meadowfield 2,740 #59 Posted December 30, 2013 Added another 10 entries to the list and updated the site. Charlie your raider is now on Any more entries? There must be another 10 new members that can add to the list? Share this post Link to post Share on other sites
Charlie Smith 142 #60 Posted December 30, 2013 I assume I'm the only Charlie with a raider in the UK? So I guess you mean me, if so, many thanks Share this post Link to post Share on other sites
meadowfield 2,740 #61 Posted December 31, 2013 I assume I'm the only Charlie with a raider in the UK? So I guess you mean me, if so, many thanks yes, I meant you Share this post Link to post Share on other sites
Charlie Smith 142 #62 Posted December 31, 2013 Sounds good to me! I'm glad to be a part Thank you. Share this post Link to post Share on other sites
Gazza 9 #63 Posted February 9, 2014 Added mine at the start of the month . Hope this helps your list . Gary Share this post Link to post Share on other sites
meadowfield 2,740 #64 Posted February 9, 2014 I saw that, need to do an update to the list. Thanks :D 1 Share this post Link to post Share on other sites
Jparkes43 329 #65 Posted February 15, 2014 Made my contribution 1 Share this post Link to post Share on other sites
