Indy443 30 #1 Posted January 30, 2013 This afternoon I drove to a gentleman's house to pick up my new snow/dozer blade and wheel weights (brand new blade and weights for $135 together). While I was down in his garage I saw that he had a 312-8 sitting in the corner and then a bunch of other WH stuff: tires, chains, more weights, a rear hitch and finally what looked like a nice seat. I inquired about it and he pulled it out and dusted it off. He didn't know what WH it had originally come off, but it was in perfect shape, no cracks or rips or really any sign of use. The seat has the two arm rests and also can be slid forward and back. This is a very attractive option as I am quite tall, and any additional leg room would be welcomed. It looks like it has some type of mounting plate attached to the bottom of the seat. My question is, would it be possible to bolt this seat up to my 312-8? If not a perfect fit, any idea of what it would take to modify it to work? He said he would ask $40 for the seat, is that a fair price? Thanks! Share this post Link to post Share on other sites
dbartlett1958 99 #2 Posted January 30, 2013 Indy, Sounds like it could be from a 520 due to the arm rests. The seat on my 416 has the back and forth adjustment which is nice, and I'm sure it would work on your tractor as well. For $40 it sounds like a great deal. Share this post Link to post Share on other sites
Indy443 30 #3 Posted January 30, 2013 Indy, Sounds like it could be from a 520 due to the arm rests. The seat on my 416 has the back and forth adjustment which is nice, and I'm sure it would work on your tractor as well. For $40 it sounds like a great deal. I'm thinking it is a seat from a 520, judging from the photos I've seen of that tractor. I would really like to find a way to make this seat work for the 312, and I thought the price sounded good. The seller said he was planning on listing up all the WH stuff he had lying around before Spring hits, so I hope I can figure a way to make this seat work before then! Has anyone mounted a 520 seat to a 312 before? I'd love to see a photo! Share this post Link to post Share on other sites
sorekiwi 761 #4 Posted January 30, 2013 I dont have a photo of my 520 seat mounting, if no-one else posts one up I'll try to remember to take some. As far as I know the 300 series rear fender pan is the same as the 520 one so it should bolt up easily. Share this post Link to post Share on other sites
Ken B 3,202 #5 Posted January 30, 2013 (edited) Does it look like this? if so and its in good shape I'd grab it. MAKE IT FIT.. Edited January 30, 2013 by Ken B Share this post Link to post Share on other sites
dbartlett1958 99 #6 Posted January 30, 2013 Indy,, If it is a 520 seat, everything should bolt right up without modification. David 1 Share this post Link to post Share on other sites
Wheel-N-It 2,978 #7 Posted January 30, 2013 I believe the only way this will be a simple bolt on installation is if you also have the hinged seat mounting assembly for the 520. If I remember correctly the 520 seat bolt pattern is not the same as the 312. You will have to take measurements to ascertain this. Otherwise as Ken B says, you will have to make it fit. $40 for the seat is an excellant price whether it readily bolts on or not. Share this post Link to post Share on other sites
dbartlett1958 99 #8 Posted January 30, 2013 Van is correct. The 520 seat will have the adjustment mechanism, but will need the optional Seat Pivot plate, Toro #112478, along with the R & L pivot brackets, #112744, 112745, along with a few other miscelaneous pieces. I forgot that I had the Deluxe seat assembly on my 416 and thought the 312 was the same. 1 Share this post Link to post Share on other sites
Indy443 30 #9 Posted January 30, 2013 Does it look like this? if so and its in good shape I'd grab it. MAKE IT FIT.. Ken B, is that the seat that came on the tractor or did you add it on later? I'm now kind of wishing I had just bought the seat when I was there...it's about a 1:50 round trip to the sellers house and mine. I think I could figure a way to make it work, but if anyone has done this before and can describe their method I would be grateful. Thank you for the replies! Share this post Link to post Share on other sites
312Hydro 474 #10 Posted January 30, 2013 Indy,, If it is a 520 seat, everything should bolt right up without modification. David x2 I agree with David, it will fit with no modification if it is a 520 seat. Share this post Link to post Share on other sites
Indy443 30 #11 Posted January 30, 2013 Do seats have any sort of ID on them to know what they came on from the factory? I've asked the seller if he'd take a look and get back to me on that. Share this post Link to post Share on other sites
546cowboy 302 #12 Posted January 30, 2013 (edited) You can't buy a cheap seat for that price around here. It does sound like a 520 seat alone without the tracks or armrests is $212. Jump on that deal quick!!!!!!!!!!!!! Edited January 30, 2013 by 546cowboy Share this post Link to post Share on other sites
Wheel-N-It 2,978 #13 Posted January 30, 2013 Indy, one thing you will learn as a Wheel Horse person is when good items like this come along, go ahead and buy them unless your gut feeling or experience tells you the price is much too high. Hang in there. It will take you about a year to get firmly footed and educated. 1 Share this post Link to post Share on other sites
KC9KAS 4,746 #14 Posted January 30, 2013 My D-200 has a seat with arm rests and moves back & forth.....For $40 it would have been mine in a heartbeat! Share this post Link to post Share on other sites
Indy443 30 #15 Posted January 31, 2013 Indy, one thing you will learn as a Wheel Horse person is when good items like this come along, go ahead and buy them unless your gut feeling or experience tells you the price is much too high. Hang in there. It will take you about a year to get firmly footed and educated. Wheel, that is good advice and it's taken. I plan on retracing my steps and picking up this seat asap. Share this post Link to post Share on other sites
Butch 194 #16 Posted January 31, 2013 Does it look like this? if so and its in good shape I'd grab it. MAKE IT FIT.. Ken B, is that the seat that came on the tractor or did you add it on later? I'm now kind of wishing I had just bought the seat when I was there...it's about a 1:50 round trip to the sellers house and mine. I think I could figure a way to make it work, but if anyone has done this before and can describe their method I would be grateful. Thank you for the replies! You should have bought it. I paid around $80 or so for mine. But then I turned around and gave it to a RS member! Share this post Link to post Share on other sites
Tankman 3,528 #17 Posted January 31, 2013 Grab the seat and run (smiling). Most would pay more and not even blink. Nice find fo' sure! Share this post Link to post Share on other sites
