WHorse1054 2 #1 Posted January 24, 2013 making an plow for my wheel horse electrio 12 and i need some info and parts. for info i need to know the following things: how long should the chain or rod be to lift and lower the plow? how wide is the plow frame where is attaches to the rear of the tractor? how does the plow attach to the rear bracket? for parts i need an rear plow bracket Share this post Link to post Share on other sites
wallfish 19,347 #2 Posted January 25, 2013 This thread should give you some good info on the dozer blades, attaching brackets and frames You can determine the length of the lift chain or linkage after your frame is mounted by having the frame raised to the highest position and then measure for the distance The frame attaches to the bracket with a 5/8 steel rod Or you can skip all of that and drive up here (about an hour north) and I'll hook you up with a dozer blade, frame and attaching bracket for $100. If you bring your tractor with you we can put it on and measure for a lift link or chain and then make one to install that too. PM me if interested Share this post Link to post Share on other sites
