Rollerman 290 #1 Posted December 1, 2007 Anybody here have any expeirence sharpening a reel mower? I have a 3 gang setup & would like to get it working best I can...maybe play with it at my inlaws big yard next year. Thanks in advance. Stephen in northern IN Share this post Link to post Share on other sites
Buzz 502 #2 Posted December 1, 2007 The wheelhorsetractormanuals3 group has the manual for a Mower Reel Gang by American Chain and Cable. It should have info on sharpening. I can't access it from work. hope it helps. Share this post Link to post Share on other sites
CasualObserver 3,414 #3 Posted December 1, 2007 Buzz, Stephen, I just looked at that page (I have the original) it's just adjustment instructions and a parts list. Nothing on the SGM-603 ipl either. I would suggest finding an old school hardware store, and see if they still have a reel sharpening machine. They used to be common when it was a common style of mower. Otherwise, good 'ol elbow grease and a file! Unless... it doesn't happen to be self sharpening does it? Like the old Eclipse mowers? Good Luck! Share this post Link to post Share on other sites
Rollerman 290 #4 Posted December 1, 2007 These are Roxy/Bonner reels? The only local guy I have found wants $65 an hour They do cut...but could use a tune up & hopeing to find a less costly way of getting them sharpened. Stephen in northern IN Share this post Link to post Share on other sites
Jim_M 179 #5 Posted December 1, 2007 Steven, I had a 5 reel gang mower once, I can't remember the brand but it was self sharpening. All you had to do was file any big nicks on the cutting edges, squirt some 30 weight on the cutting edges and mow, it took care of the rest. I think most of them work that way, unless it's really an old one. Jim Share this post Link to post Share on other sites
Mith 2 #6 Posted December 2, 2007 You can hone the cylinders on the mower, but to sharpen them you need to remove the cylinders and bottom blades and put them on a sharpening machine really. A properly sharpened cylinder should be able to cut paper, as well as a sharp pair of scissors would, all the way along. In short, they really need to be done on a machine. If you take the cylinders and bottom blades out yourself it shouldn't be too expensive. Share this post Link to post Share on other sites
Buzz 502 #7 Posted December 2, 2007 Here's a thought. If you have any golf courses near-by, ask their groundskeepers where they get theirs sharpened. If a shops has all of the equipment necessary it might not be too expensive. Share this post Link to post Share on other sites
Rollerman 290 #8 Posted December 2, 2007 Buzz thanks for the ideas. I actually looked into 3 courses around here...2 are municipal owned & could not do it??? The 3rd was a fancy private clup & they kind of had there nose up in the air. I'm going to check a few more out though...golf course maintanece shops seem to be the best bet. Stephen in northern IN Share this post Link to post Share on other sites
wesley 32 #9 Posted February 6, 2008 Hi l no this post is old but am reading my way through them all , now if this helps you can sharpen them on a lathe , have done loads of them, just put a damp cloth etc over the lathe bed first as the grinding dust get in the the bed, then just mount a small angle grinder on to the tool post and there you go a machine to sharpen mower cylinders, and yes as one of the other replys state you should be able to cut paper afterwards , hope this is of help. wes Share this post Link to post Share on other sites
CasualObserver 3,414 #10 Posted August 15, 2008 Stephen, I know this post is forever old, but I came across this page and thought you (and others) might benefit from it. Reel Mower Sharpening B) Share this post Link to post Share on other sites
Teddy da Bear 11 #11 Posted August 15, 2008 Stephen, I have a 9 1/2 foot 7 gang reel mower. I have a kit for mine. Actually the action of the mower itself keeps it sharp. It only does not cut well if it gets out of adjustment. Or your mowing rocks....lol Actually the kit I have has a "lapping" compound and your suppose to elevate each reel and run it in reverse to touch up the edges. Share this post Link to post Share on other sites
