grinchsr 653 #1 Posted January 14, 2013 Will a starter from a M16S spec 711522 fit a M16S spec 711523 engine? I just purchased one and compared them and the nose on the purchased starter is shorter. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted January 14, 2013 There's a before/after serial number break @ 2235000013 for the starter but I don't know the difference. Is the length of the shaft sticking out beyond the drive gear different on the two you have? Share this post Link to post Share on other sites
grinchsr 653 #3 Posted January 14, 2013 I don't have mine out of the tractor yet. I planned on doing it in the spring. I don't use it in winter. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted January 14, 2013 So how did you compare 'nose' length? :scratchead: Share this post Link to post Share on other sites
grinchsr 653 #5 Posted January 15, 2013 Mine has a cast aluminum ribbed cone on the end where as the replacement has no cone on the end. The motor housings are the same length. Looks like this weekend I am going to pull the old one a compare them side by side. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #6 Posted January 15, 2013 The "cast aluminum ribbed cone" is part of the bearing (crankcase closure) plate on a Magnum single. You have to be extremely careful when loosening the bolts that hold the starter to the bearing plate as they twist off easily. The starter can also "fall apart" once it's unbolted. You will more than likely have to remove the dipstick tube from the engine block ~ which is made much easier by removing the drive belt guard from the right side of the tractor. I highly recommend purchasing a new gasket for the dipstick tube just in case the old one tears. Here's a link to the service manual: CLICK HERE Share this post Link to post Share on other sites
grinchsr 653 #7 Posted January 15, 2013 THANKS for the info TT. Hopefully it will not be real cold this weekend so I can get this done Share this post Link to post Share on other sites
