Old Iron 0 #1 Posted January 13, 2013 I recently blew the connecting rod in a K241. The crank has aluminum galling on the bearing surface for the rod. Is there even a remote possability the crank will clean up? As it stands now, I need to replace the piston, rings, and hone the cylinder. I'm hoping a new crank doesn't make the list... Share this post Link to post Share on other sites
illinilefttackle 399 #2 Posted January 13, 2013 Hello-I wish I had good news, but IMO , that is the one part of an engine you can just "clean up" after a major failure-even if it measured within spec-it would almost certainly be "out of round". To be safe-take the crank to a machine shop-have them tell you what they have to turn it to-order your rod from there-the rest you "might" get by with. I wouldn't-do it right-have them check the bore, etc. then go from there-you can get rebuild kits pretty reasonable on ebay- Hope this helps-Al Share this post Link to post Share on other sites
Old Iron 0 #3 Posted January 13, 2013 Thanks for your opinion. I've been a Machinist for over 20 years and agree with what you recomend. I guess I am just in denile and was hoping someone might say "so sweat...just get it trued up and you'll be fine!" I want to make the 1057 run like new so I guess I know what I have to do... Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted January 13, 2013 In the last four months I have sent two to be cleaned & polished after oil starvation-related rod failure. They have both cleaned up perfectly and are still in spec. Of course that doesn't mean that yours will be fine too, but it might give you some hope. If you want to do it yourself, soak the crankpin area in muriatic acid to remove all traces of the aluminum and use crocus cloth to polish. Throw the mic on it and see what it measures. :handgestures-thumbup: Share this post Link to post Share on other sites
oldredrider 2,553 #5 Posted January 13, 2013 Been there, done that. Cleaned up an aluminized K301 crank with muriatic acid, put in a new rod and piston...runs smooth and sweet. As said above, just check the specs. Good luck. Share this post Link to post Share on other sites
can whlvr 994 #6 Posted January 15, 2013 my 241 blew a rod also and i did as tt stated and its been fine after the rebuild Share this post Link to post Share on other sites
