WHEEL HORSE BILL 7 #1 Posted January 6, 2013 I tried doing that today and the lock washer falls out everytime.is there a way of keeping that washer tight on there.I've seen pictures with it upside down and it looks awesome but am I doing somthing wrong. Share this post Link to post Share on other sites
Kelly 1,038 #2 Posted January 6, 2013 (edited) What lock washer???? Or do you mean the C clip or snap ring? on top of the spindle? if so they are not made to support the weight of the tractor, flip the axle and put the spindles in the right way, another thing to watch if dropping the front a long ways is the oil level in the engine will change with the tilt, most of these engines are splash lube from the bottom of the pan. Edited January 6, 2013 by Kelly Share this post Link to post Share on other sites
WHEEL HORSE BILL 7 #3 Posted January 6, 2013 So I can't drop the front with that axle correct. How can I drop the front end is there a different way. I so want the look. Share this post Link to post Share on other sites
wh-jason 33 #4 Posted January 6, 2013 i use lawn ranger front tires. it looks good and its an easy swap. Share this post Link to post Share on other sites
Big Jake 18 #5 Posted January 6, 2013 My C120 I made new spindles. Didnt flip the axle Jake 1 Share this post Link to post Share on other sites
TT-(Moderator) 1,172 #6 Posted January 6, 2013 I firmly believe that proper hitch design and weight placement is much more important on a stock tractor. I know, I know..... it's all about the 'look'. I used an axle from a B series LAWN tractor, C series spindles, and 6" front wheels with triple-ribs on an old Raider I stuck together for the fun of it. (rear tires are 23-10.50X12) Here's a video of my son putting it to work: For all of you non-believers ~ that's just a stock 10hp HH-100 Tecumseh with a straight pipe. :P Share this post Link to post Share on other sites
chris11 184 #7 Posted January 6, 2013 I agree with Terry, with the engine not having a oil pump. your better not lowering it . mine i made spindles but i also have a oil pump on engine. Share this post Link to post Share on other sites
baerpath 517 #8 Posted January 7, 2013 This has a 200 series front axle with 4 inch tri ribs. Share this post Link to post Share on other sites
