3609horse 27 #1 Posted January 4, 2013 I know more HP is better but how would a 10hp gear drive tractor do with a 36" blower? Thanks, Gene.. Share this post Link to post Share on other sites
Sparky-(Admin) 23,983 #2 Posted January 4, 2013 I've used a single stage blower with a 12hp Kohler single, 16hp Onan Twin and a 18hp Kohler Magnum. The Onan and the 18 Kohler tossed the snow with ease. My 12 Kohler (C-125) had to be babied a bit in the deeper stuff. Yes it will move snow, but it will work harder and you'll have to do it slower in my opinion. Mike......... Share this post Link to post Share on other sites
littleredrider 409 #3 Posted January 4, 2013 I have a 13 horse on mine and does pretty good. Sometimes it feels like it's hardly working hard, can't really hear the engine load.... Share this post Link to post Share on other sites
can whlvr 994 #4 Posted January 5, 2013 a 10 might do it but its a little small,depends on how much snow and like sparky said you will have to go slow at times,ive run my 42,s with a 10,12 13,14 16 hp motors and the 16 rules,but if its your only option it will do it,and a 36 is easier to turn than a 42,i took the wings off of mine when running the smaller engines Share this post Link to post Share on other sites
3609horse 27 #5 Posted January 5, 2013 Thanks for the input. I have a 16hp twin with a blower but I am putting together a 10hp black hood and just wondering how it might handle a snow blower. It's a nice running tractor so far, just looking to see if I am wasting my time. I don't mind going slow, just gives me more seat time., Thanks, Gene... Share this post Link to post Share on other sites
racin_ny 25 #6 Posted January 5, 2013 I had problems with the blackhood interfering with the belt driving the blower you may want to check that out. The hood was too wide where the belt passes to go to the blower. ;-) Share this post Link to post Share on other sites
3609horse 27 #7 Posted January 5, 2013 I had problems with the blackhood interfering with the belt driving the blower you may want to check that out. The hood was too wide where the belt passes to go to the blower. I was afraid of that. I have two others and when I look down the side with the PTO it looks really close, If this doesn't work it's going to put a kink in my plans. I will find out this week when i take it out of the shed for it's first run in the snow. Thanks, Gene... Share this post Link to post Share on other sites
Wyattrrp 59 #8 Posted January 13, 2013 Just a note to say my Black Hood C-125 and my 312-8 have both run a 42 inch single stage pertty well. If wet heavy snow 6 inches or more the 12 HP does work hard but still functions well. In powder it has no problem doing 42 inch wide. If the 10 HP has a power issue you can remove the wings which narrows the feed to 36 inches. Normally only the first pass is full width anyway so the remaining passes you can overlap the new snow 2/3 or whatever works well for you. The belt rounting is not an issue with either tractor. The manual states the belt should be mounted on the outer PTO pulley and the belt then is well beyond the hood tins. Some guys on here like to put the belt on the inner pulley. which is a larger diameter thus making the blower spin faster. The belt may then be so close to the hood side tins it could hit. I figure it already runs pretty darn fast on the outer pulley since you are supposed to run full throttle at 3600 RPM. The auger is moving fast enough for me and does throw snow pretty well. Here is a link to my video last year of the 312 showing fairly light snow that I plowed to the side of the driveway then blew it onto the grass. You can hear the 12 HP working but id throws it pretty far considering it is on the outer maller pulley as called for. 1 Share this post Link to post Share on other sites
Forest Road 594 #9 Posted January 13, 2013 I know 2 guys running singles with 10hp tractors. They're both very happy Share this post Link to post Share on other sites
ol550 838 #10 Posted January 14, 2013 (edited) This is a retired snowblower, but it had 3000 hp. Kind of a special purpose though. IMG] Edited January 14, 2013 by ol550 1 Share this post Link to post Share on other sites
Martin 2,133 #11 Posted January 14, 2013 hey mike, does that use the tach-a-matic setup? what size belts? Share this post Link to post Share on other sites
Wyattrrp 59 #12 Posted January 14, 2013 AND no Sitff Wire in front of the auger to stop the hand injury when reaching in to unclog it from wet heavy snow! Shame Shame. But.... I bet it did a good job of thorwing 8 ft drifts!! With that I would need more rear weights! Share this post Link to post Share on other sites
ol550 838 #13 Posted January 15, 2013 No tach a matic hookup. Would need extra weight to push it. Weighed in at 367,400 pounds and required 3 or 4 engines to push it 4-6 mph. The blower fan is 12 ft. :omg: Share this post Link to post Share on other sites
Wyattrrp 59 #14 Posted January 15, 2013 Any Video of it working??? Share this post Link to post Share on other sites
ol550 838 #15 Posted January 15, 2013 Any Video of it working??? This one is in a museum in St Louis MO. YouTube has similar ones just search railroad snow blower. Share this post Link to post Share on other sites
liketoplayto 6 #16 Posted January 15, 2013 My dad used his 1975 c100 with ten hp and blowed snow in lansing michigan thru out the neigbor hood and a apartment complex ajasant from his back lot he used it till snow blower wore out in 2005 and then he bought a new snow blower and it still going today just my 2 cents thanks 1 Share this post Link to post Share on other sites
varosd 1,185 #17 Posted January 18, 2013 I have used my good ole B-80 w/o issues but as all have commented before, common sense rules. I don't have behemoth a 2 stage blower, but still fun. picture from the other year...when we had snow...sigh! 1 Share this post Link to post Share on other sites
3609horse 27 #18 Posted January 18, 2013 I have used my good ole B-80 w/o issues but as all have commented before, common sense rules. I don't have behemoth a 2 stage blower, but still fun. picture from the other year...when we had snow...sigh! Thats a nice looking tractor you have. Thanks for the response. I got to use my 10hp this last storm and it did a very good job, even when it was wet and heavy I just had to adjust the speed to the load. Thanks to everyone that commented. Gene.. Share this post Link to post Share on other sites
littleredrider 409 #19 Posted January 18, 2013 If we get any more snow this year, I might mount the blower on the diesel, see how that does. So far I have yet to hear it struggle.... Share this post Link to post Share on other sites
