kloe0699 12 #1 Posted January 2, 2013 The clutch is slipping on my C-175 when I try to turn the snowblower on. I tried cleaning and sanding it but it's pretty worn. Its a series I kt17. I took the clutch plate and pto bell off and was going to replace them with ones from a series II parts motor but quickly ran into trouble. The series I plate slid off over the shaft while the series II slid off shaft and all. Is there anyway to swap these? Share this post Link to post Share on other sites
Kelly 1,033 #2 Posted January 2, 2013 The clutch plate should be the same, it may just be stuck on the PTO sleeve, try tapping it off the sleeve. or just use the sleeve with it, slide the sleeve off the other engine. Share this post Link to post Share on other sites
