roger.johnson 0 #1 Posted December 30, 2012 I am new to this, and I was wondering what I could do to my engine to get more power out of it. I have an 18hp v twin briggs and stratton. Thanks guys! Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #2 Posted December 30, 2012 :WRS: Vanguard twin? Application? Share this post Link to post Share on other sites
Don1977 606 #3 Posted December 30, 2012 If cleaning the carburetor doesn't help I would try changing ignition module the vanguard has two.. If its weak it can run good with no load and be a dog when loaded. You could check the plugs after pulling it hard to see if they are clean or carboned up. This can also tell if one is bad. Share this post Link to post Share on other sites
AMC RULES 37,260 #4 Posted December 30, 2012 What you're saying is it's running good as is, and you're looking for more performance? Share this post Link to post Share on other sites
roger.johnson 0 #5 Posted December 30, 2012 yes the vanguard twin, it is on my work horse gt -1848. The main purpose for this machine is now pushing snow, and I am looking to get it running better, if possible. It runs ok now, I am just looking at doing some small things to increase the performance if possible. Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #6 Posted December 30, 2012 I think the Vanguard twins work quite well in stock form. It is possible to get 50hp out of what once was 16 or 18, but you need a big wallet. Check out this site: http://www.performancevtwins.com/ Share this post Link to post Share on other sites
TheReDStAnG 4 #7 Posted December 30, 2012 Are you sure you have a vanguard v twin? That model came factory with an 18 hp opposed twin Briggs engine. Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #8 Posted December 30, 2012 That model came factory with an 18 hp opposed twin Briggs engine. So did mine, but I'm trying to change that: Share this post Link to post Share on other sites
AMC RULES 37,260 #9 Posted December 30, 2012 PM this guy. http://www.wheelhorseforum.com/user/5219-rooster/ Share this post Link to post Share on other sites
