Ryanflathead45 11 #1 Posted December 27, 2012 When I was out plowing today the tie rod came loose on the GT14. It looks like at one time the joint had wore out came apart, so somebody drilled a hole through the joint and then put a bolt all the way through it. it worked but the nut worked its way off. I fixed it by using a shoulder bolt a couple of nuts. But I would like to fit it correctly. Where is good place to buy these joints?? Its the joint that connects to the wheel spindle by the way. Thanks in advance. 1 Share this post Link to post Share on other sites
Duff 206 #2 Posted December 27, 2012 Ryan, could you post a picture of the failed unit? I don't have any experience with the GT's, but I fab my own tie rods for 300/400-series machines out of readily available parts from McMaster-Carr, partly because some of the originals I had were worn, but mostly because I like a little toe-in on my tractors' front ends. Duff :thumbs: 1 Share this post Link to post Share on other sites
KC9KAS 4,745 #3 Posted December 27, 2012 These guys have it all......click on link. http://www.mcmaster.com/#tie-rod-ends/=ks3b7n Share this post Link to post Share on other sites
Tim 97 #4 Posted December 27, 2012 duff you would know the part numbers for these would you Share this post Link to post Share on other sites
KC9KAS 4,745 #5 Posted December 27, 2012 Heavy Duty Ball Joint Linkages Male-Threaded Shank Female-Threaded Shank Able to stand up to frequent use, these linkages offer superior wear resistance. All are ball joint rod ends with the studs attached to simplify mounting. They have a chrome-plated, bearing-steel ball stud that’s machined to fit perfectly inside its housing, which is zinc-plated steel. Linkages are great for clutches, throttles, and shift control rods. Periodic lubrication may be required to keep them operating smoothly. Maximum ball swivel is approximately 50°. They are not load rated. Linkages with grease fitting are easy to lubricate. Right-Hand Threaded Stud Left-Hand Threaded Stud Stud and Shank Thread Size Lg. (A) Stud Lg. ( Lg. © Thread Lg. (F) Thread Dp. (F) Each Each Male Right-Hand Threaded Shank Without Grease Fitting 10-32 1 1/64" 1/2" 1 1/4" 3/4" __ 60645K211 $4.91 60645K213 $4.91 1/4"-28 1 1/32" 9/16" 1 9/16" 1" __ 60645K221 4.76 60645K223 4.76 5/16"-24 1 7/32" 11/16" 1 7/8" 1 1/4" __ 60645K231 4.87 60645K233 4.87 3/8"-24 1 9/16" 29/32" 1 15/16" 1 1/4" __ 60645K241 5.73 60645K243 5.73 7/16"-20 1 3/4" 1 1/16" 2 1/8" 1 3/8" __ 60645K251 7.09 60645K253 7.09 1/2"-20 2" 1 1/8" 2 7/16" 1 1/2" __ 60645K261 9.04 60645K263 9.04 5/8"-18 2 1/2" 1 1/2" 2 5/8" 1 5/8" __ 60645K271 14.40 60645K273 14.40 3/4"-16 3" 1 13/16" 2 7/8" 1 3/4" __ 60645K281 21.02 60645K283 21.02 With Grease Fitting 3/8"-24 1 9/16" 29/32" 1 15/16" 1 1/4" __ 4444T811 6.20 4444T813 6.20 7/16"-20 1 3/4" 1 1/16" 2 1/8" 1 3/8" __ 4444T821 7.59 4444T823 7.59 1/2"-20 2" 1 1/8" 2 7/16" 1 1/2" __ 4444T831 9.59 4444T833 9.59 5/8"-18 2 1/2" 1 1/2" 2 5/8" 1 5/8" __ 4444T841 15.07 4444T843 15.07 3/4"-16 3" 1 13/16" 2 7/8" 1 3/4" __ 4444T851 21.84 4444T853 21.84 Male Left-Hand Threaded Shank Without Grease Fitting 10-32 1 1/64" 1/2" 1 1/4" 3/4" __ 60645K212 4.91 60645K214 4.91 1/4"-28 1 1/32" 9/16" 1 9/16" 1" __ 60645K222 4.76 60645K224 4.76 5/16"-24 1 7/32" 11/16" 1 7/8" 1 1/4" __ 60645K232 4.87 60645K234 4.87 3/8"-24 1 9/16" 29/32" 1 15/16" 1 1/4" __ 60645K242 5.73 60645K244 5.73 7/16"-20 1 3/4" 1 1/16" 2 1/8" 1 3/8" __ 60645K252 7.09 60645K254 7.09 1/2"-20 2" 1 1/8" 2 7/16" 1 1/2" __ 60645K262 9.04 60645K264 9.04 5/8"-18 2 1/2" 1 1/2" 2 5/8" 1 5/8" __ 60645K272 14.40 60645K274 14.40 3/4"-16 3" 1 13/16" 2 7/8" 1 3/4" __ 60645K282 21.02 60645K284 21.02 With Grease Fitting 3/8"-24 1 9/16" 29/32" 1 15/16" 1 1/4" __ 4444T812 6.20 4444T814 6.20 7/16"-20 1 3/4" 1 1/16" 2 1/8" 1 3/8" __ 4444T822 7.59 4444T824 7.59 1/2"-20 2" 1 1/8" 2 7/16" 1 1/2" __ 4444T832 9.59 4444T834 9.59 5/8"-18 2 1/2" 1 1/2" 2 5/8" 1 5/8" __ 4444T842 15.07 4444T844 15.07 3/4"-16 3" 1 13/16" 2 7/8" 1 3/4" __ 4444T852 21.84 4444T854 21.84 Female Right-Hand Threaded Shank Without Grease Fitting 10-32 1 1/64" 1/2" 1 1/16" __ 1/2" 60645K411 4.70 60645K413 4.70 1/4"-28 1 1/32" 9/16" 1 5/16" __ 11/16" 60645K421 4.55 60645K423 4.55 5/16"-24 1 7/32" 11/16" 1 3/8" __ 11/16" 60645K431 4.66 60645K433 4.66 3/8"-24 1 9/16" 29/32" 1 5/8" __ 13/16" 60645K441 5.49 60645K443 5.49 7/16"-20 1 3/4" 1 1/16" 1 13/16" __ 15/16" 60645K451 6.79 60645K453 6.79 1/2"-20 2" 1 1/8" 2 1/8" __ 1 1/16" 60645K461 8.66 60645K463 8.66 5/8"-18 2 1/2" 1 1/2" 2 1/2" __ 1 3/8" 60645K471 13.79 60645K473 13.79 3/4"-16 3" 1 13/16" 2 7/8" __ 1 9/16" 60645K481 20.13 60645K483 20.13 With Grease Fitting 1/4"-28 1 1/32" 9/16" 1 5/16" __ 11/16" 4444T911 5.09 4444T913 5.09 5/16"-24 1 7/32" 11/16" 1 3/8" __ 11/16" 4444T921 5.32 4444T923 5.32 3/8"-24 1 9/16" 29/32" 1 5/8" __ 13/16" 4444T931 6.20 4444T933 6.20 7/16"-20 1 3/4" 1 1/16" 1 13/16" __ 15/16" 4444T941 7.59 4444T943 7.59 1/2"-20 2" 1 1/8" 2 1/8" __ 1 1/16" 4444T951 9.59 4444T953 9.59 5/8"-18 2 1/2" 1 1/2" 2 1/2" __ 1 3/8" 4444T961 15.07 4444T963 15.07 3/4"-16 3" 1 13/16" 2 7/8" __ 1 9/16" 4444T971 21.84 4444T973 21.84 Female Left-Hand Threaded Shank Without Grease Fitting 10-32 1 1/64" 1/2" 1 1/16" __ 1/2" 60645K412 4.70 60645K414 4.70 1/4"-28 1 1/32" 9/16" 1 5/16" __ 11/16" 60645K422 4.55 60645K424 4.55 5/16"-24 1 7/32" 11/16" 1 3/8" __ 11/16" 60645K432 4.66 60645K434 4.66 3/8"-24 1 9/16" 29/32" 1 5/8" __ 13/16" 60645K442 5.49 60645K444 5.49 7/16"-20 1 3/4" 1 1/16" 1 13/16" __ 15/16" 60645K452 6.79 60645K454 6.79 1/2"-20 2" 1 1/8" 2 1/8" __ 1 1/16" 60645K462 8.66 60645K464 8.66 5/8"-18 2 1/2" 1 1/2" 2 1/2" __ 1 3/8" 60645K472 13.79 60645K474 13.79 3/4"-16 3" 1 13/16" 2 7/8" __ 1 9/16" 60645K482 20.13 60645K484 20.13 With Grease Fitting 1/4"-28 1 1/32" 9/16" 1 5/16" __ 11/16" 4444T912 5.09 4444T914 5.09 5/16"-24 1 7/32" 11/16" 1 3/8" __ 11/16" 4444T922 5.32 4444T924 5.32 3/8"-24 1 9/16" 29/32" 1 5/8" __ 13/16" 4444T932 6.20 4444T934 6.20 7/16"-20 1 3/4" 1 1/16" 1 13/16" __ 15/16" 4444T942 7.59 4444T944 7.59 1/2"-20 2" 1 1/8" 2 1/8" __ 1 1/16" 4444T952 9.59 4444T954 9.59 5/8"-18 2 1/2" 1 1/2" 2 1/2" __ 1 3/8" 4444T962 15.07 4444T964 15.07 3/4"-16 3" 1 13/16" 2 7/8" __ 1 9/16" 4444T972 21.84 4444T974 21.84 Oh, didn't copy & paste very well. Go to their web site. 1 Share this post Link to post Share on other sites
Ryanflathead45 11 #6 Posted December 28, 2012 I went to the website. The only thing that is confusing is the male and female ends are the same size. The stock tie rod has a 3/8" stud and the female end is 1/2" Should I get the connector from McMaster Carr with both male and female ends that are 3/8"? Are they going to be as strong as the stock ones? Share this post Link to post Share on other sites
glgrumpy 35 #7 Posted December 30, 2012 I never found one of those rods or ends for my 14. The one going back to the steering arm on box needs a way to hold itself up corectly. Never figured that one out, used diff generic joint with a shoulder bolt there. Rod now hangs down some, more than I like, but doesn't seem to bind in turns. If you find Mixed size ones, let us know. Share this post Link to post Share on other sites
Don1977 605 #8 Posted December 30, 2012 On my C-120 I used female 1/2" heim joints with 1/2" hole. Used 1/2" to 3/8" flange bearings and spacers with 3/8" bolts to the steering arms. They move around some but it doesn't hurt the steering. Share this post Link to post Share on other sites
