gcole 36 #1 Posted December 24, 2012 Hi again guys I was wondering how to remove the the lift handle on my 75 c-120 it needs a new spring and the dog to be built up. Thanks in advance Share this post Link to post Share on other sites
jdog_kustoms 82 #2 Posted December 24, 2012 there is 2 screw on the left side engine side of the dash tower you unbolt that then piviot the rockshaft and handle out Share this post Link to post Share on other sites
Kelly 1,033 #3 Posted December 24, 2012 There are 3 bolts 1/2" head two are facing the engine at the bottom of the handle, one around the side, at the base of the handle, then inside of the dash tower you will see a large cotter clip/hairpin clip, remove that, some can be fun to get out, then slide the handle into the cast iron block the 3 bolts held in place, or push the block inwards what ever is easier, then you can rock the handle around till it comes out. Oh you may have to unhook the lift parts for the T bar that lifts the deck. Share this post Link to post Share on other sites
