glgrumpy 35 #1 Posted December 22, 2012 Commado 800 with just 4spd axle. 3rd gear was blocked off with plate. Removed it and tried a drive. No noise, but pops out right away, unless I hold lever over. What might I be looking at to fix? Be splitting then? Think just a bent shift fork? Are there any slugs/springs to hold detents to check first? Share this post Link to post Share on other sites
Coadster32 793 #2 Posted December 23, 2012 Most likely a rounded out gear engagement from past grindings. Third gear has the least engagement by design. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #3 Posted December 23, 2012 A little reading material courtesy of the search box up there in the top right corner: 1 Share this post Link to post Share on other sites
meadowfield 2,758 #4 Posted December 23, 2012 Third gear sucks on some old transmissions - 50/50 abuse, ill maintenance.... Easiest fix is to drop an 8 speed in, providing you have the hubs and are prepared to maybe have to swap a pulley/belt. Unless you can easily lay your hands on a good set of gears and are confident to rebuild.... Mark Share this post Link to post Share on other sites
