Wheel-N-It 2,978 #1 Posted December 22, 2012 Hey Guys, I am changing the oil in the C125 I brought home a few days ago. It has a 12hp K kohler. It is rubber mounted. I need to know the oil capacity for this engine. It is my first rubber mounted Wheel Horse. If someone could jump in while the old oil is draining out, that sure would help me. Thank you and Merry Christmas! Van Share this post Link to post Share on other sites
varosd 1,185 #2 Posted December 22, 2012 looks like 1 1/2 quarts engine oil by the lube guide 8 speed tranny is 2 quarts Share this post Link to post Share on other sites
Wheel-N-It 2,978 #3 Posted December 22, 2012 Thank you much Don:) That gives me a good baseline. BTW, I am really likiing this Blackhood ! 1 Share this post Link to post Share on other sites
rmaynard 16,836 #4 Posted December 22, 2012 (edited) The "nominal" capacity is 1-1/2 qts, but the best procedure as recommend in the manual is to put in a quart then slowly add oil until the full mark is reached on the dip stick. Sent from my MB520 using Tapatalk 2 Edited December 22, 2012 by rmaynard Share this post Link to post Share on other sites
varosd 1,185 #5 Posted December 22, 2012 The "nominal" capacity is 1-1/2 qts, but the best procedure as recommend in the manual is to put in a quart then slowly add oil until the full mark is reached on the dip stick. Sent from my MB520 using Tapatalk 2 Bob, you are spot on! :D Share this post Link to post Share on other sites
Wheel-N-It 2,978 #6 Posted December 23, 2012 Thank you Guys It took 1 quart, and 26ozs to fill it. I sure would like to see this engine hold more oil, but I know its engineered to this specification. On the other hand the solid mounted kohler K341 in the 416-8 I bought a few weeks ago holds 2 quarts, and 29 ozs of oil. Share this post Link to post Share on other sites
