fourwheels0 191 #1 Posted December 18, 2012 what air pressure should i run in my rear ag tires with a front end loader and rear weight box. tires are not loaded. right now it's 12psi. Share this post Link to post Share on other sites
Kelly 1,033 #2 Posted December 18, 2012 I air mine till the tread sets flat, about 12 to 16 PSI on the rear, fronts I run about 20PSI in a 4 ply tire Share this post Link to post Share on other sites
Marv 991 #3 Posted December 20, 2012 The owners manual for the loader states "adjust tire pressure in all four tires to 25-30 PSI". It does not specify ag or turf tread though. Marv Share this post Link to post Share on other sites
cheesegrader 434 #4 Posted December 20, 2012 Mine are 25psi all the way around (rear ags, front 4ply) No science behind it, just the eyeball test. To be honest, I'm tempted to add a little more in the winter. Lower pressure just looks too soft. Share this post Link to post Share on other sites
Audioshot 2 #5 Posted December 23, 2012 You'll need enough air pressure so that the tires retain their shape under max load without exceding the max PSI rating of the rim and tire. Share this post Link to post Share on other sites
